danishdeshmuk
Advanced Member level 1
Hi
I have a strange kind of problem that i am facing with my AC Split , the AC Split is 1.5 tonns having Running Rated Amps 7.5 Amps .....
The problem is that when i switch on my AC Split and as its compressor starts it takes around 7.5 Amps load (as it should be cause its normal) but after 4 to 5 minutes its load decrease to 3 Amps though its compressor is running , the fan running smoothly also there's no heating signs of compressor (not so heat up) .....
Then when i switch it off at that moment and try to switch it on its compressor it doesnt start up at all though i give it 3 minutes time .....
But if i give it couple of hours break the compressor starts up but the behavior remains the same i.e. after 4 to 5 minutes its load decrease to 3 Amps from 7.5 Amps ...
Its a 220 V Ac supply AC Split and the voltage is around 216 to 220 V Ac ...
what might be the problem ?
