haneet
Full Member level 3
file is not valid elfclass32 library
Hi Guyz,
I am facing a problem when i am compiling the verilog file attached
Here if u see i have mentioned the $monitor.
when i perform the command
$monitor ("time=%t,PADI_bus_rst=%b",$time,chip.PADI_bus_rst);
then it says:
Elaborating the design hierarchy:
ncelab: *W,MISSYST: Unrecognized system task or function (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
If item was defined in a shared-object library, the problem could be:
libvpi.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library.
libpli.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library..
ncelab: *E,CUVHNF (./top/tb.v,327|58): Hierarchical name component lookup failed at 'chip'.
and when i do this then no problem:
$monitor ("time=%t,PADI_bus_rst=%b",$time,PADI_bus_rst);
I even checked with the path of the hierarchy if i have given somethng wrong. but that is not the case. The path is also correct.
can any1 help me?
HANEET
Hi Guyz,
then it says:
can any1 help me?
HANEET
