problem reading conversion and calculating power
ghattas.akkad
Member level 1
hello i am trying to build a wattmeter using mplab
following the documents instructions in this pdf but im not getting correct results and cant figure out why
i think the problem is with the A/D reading but couldnt figure out how to fix it
it would be great if someone can take a look at it
thank you
  • power meter! (3).zip
  • WattMeter.pdf
thank you
what microcontroller and compiler are you using?
if you vary the load does the ADC reading change?
sorry, i didn´t read through the zip file...
"not correct results" what results do you get, and what do you expect?
Maybe step by step:
(use known voltages, known resistive loads, use a voltmeter and an amperemeter to compare values)
* just make sure that the adc is working
* then only make voltage readings and display it. Are they correct?
* then do the current readings an display it...
* then do the power calculations.
Then tell us what you see, and we can better assist you...
hope this helps
Klaus
i am using pic18f4520 on mplab and C18 compiler yes it changes value when the load varies
i think the problem is with the A/D conversion formula i am using i managed to read the inputted values correctly now i just have to rescale them back
to the original voltage and current scales the problem some calculation problem where the result seems to vary whenever i change the values from 2 to 2.0
when i multiply by 10 it gives a result and when i multiply by 10.0 it gives another i dont understand this
Maybe step by step:
hope this helps
Klaus
thank you that was helpful i followed the steps and fixed the reading i still have to rescale the values to the original input voltage and current
so i can calculate the power on the ranges 0-230V and 0-5A the problem is some calculation errors that are a bit confusing and im getting some unexpected results
The "AC Watt Meter" project paper is assuming that you know how to read 10 Bit ADC values and thus doesn't discuss the details. But it's not done correctly in your code. I'm not using C18 and don't know how ADRES is generated. Presuming it is a correctly right adjusted 10-Bit values, it surely can't be stored in a char array.
Verify that you get plausible raw values and then trace the calculation step by step.
Refer this project **broken link removed**
an int array wont compile stating that there is not enough place and i have a question regarding mikroC compiler when u use ADC_Read the returned value for example is between 0-255 and i have to rescale it by multiplying it by vdd/1024 right ?
thank youu
MPLINK 4.40, Linker
Device Database Version 1.3
Copyright (c) 1998-2011 Microchip Technology Inc.
Error - section '.udata_PowerM.o' can not fit the section. Section '.udata_PowerM.o' length=0x00000135
Errors : 1
this is the linker error
ok i fixed the linker error with his code
	#pragma udata udata1
	unsigned int ResultV[100];
	#pragma udata udata2
	unsigned int ResultI[100];
but the A/D conversion following the papers formula is still not working for me
Am = (5.0/1024.0)*(5.4054);
Vm = (5.0/1024.0)*(230.0);
ADCON0 = 0b11000001; 										//  A/D on, RC clock, select RA0
ADCON0bits.GO = 1;											//  start A/D conversion
while (ADCON0bits.NOT_DONE);								//  wait until A/D conversion is complete
ResultV[i] = ADRES;
ADCON0 = 0b11000101; 										//  A/D on, RC clock, select RA1
ResultI[i] = ADRES;
tempV=Vm*((ResultV[i]/10)-2.5);
tempI=Am*((ResultI[i]/10)-2.5);
RMSV = RMSV + (tempV)*(tempV);
RMSA = RMSA + (tempI)*(tempI);
Pin += (tempV)*(tempI);
i guess ill change the paper formulas... ill read A/D data scale it to 0-5V range than rescale them back to the original inputs
with some reversed calculations based on the implemented circuits
