majid_valentine
Junior Member level 3
bascom spi
hi all
what is problem in my program???
data dont recived correctly by slave!!!!!!!!!!!!!
master program:
$regfile = "m32def.dat"
$crystal = 8000000
Config Lcdpin = Pin , Db4 = Pina.4 , Db5 = Pina.5 , Db6 = Pina.6 , Db7 = Pina.7 _
, E = Pina.3 , Rs = Pina.2
Config Lcd = 16 * 4
Config Spi = Hard , Interrupt = On , Data Order = Lsb , Master = Yes , _
Polarity = High , Phase = 1 , Clockrate = 4
Enable Spi
Dim A As Byte
Spiinit
For A = 0 To 10
Spiout A , 1
Wait 1
Next A
End 'end program
slave program:
$regfile = "m16def.dat"
$crystal = 8000000
Config Spi = Hard , Interrupt = On , Data Order = Lsb , Master = No , _
Polarity = High , Phase = 0 , Clockrate = 4
Config Lcd = 16 * 4
Enable Interrupts
Enable Spi
On Spi Yes
Dim A As Byte
Spiinit
Cls
Home Upper
Lcd " NO SPI"
Home Lower
Do
Wait 1
Loop
End 'end program
Yes:
Disable Interrupts
Spiin A , 1
Lcd A
Enable Interrupts
Return
Added after 1 hours 10 minutes:
i realy need to help?????
any body can't help me?????
pleas!!!!!!!!
hi all
master program:
$crystal = 8000000
Config Lcd = 16 * 4
Enable Spi
Dim A As Byte
Spiinit
For A = 0 To 10
Spiout A , 1
Wait 1
Next A
End 'end program
slave program:
$crystal = 8000000
Config Lcd = 16 * 4
Enable Interrupts
Enable Spi
On Spi Yes
Dim A As Byte
Spiinit
Cls
Home Upper
Lcd " NO SPI"
Home Lower
Do
Wait 1
Loop
End 'end program
Yes:
Disable Interrupts
Spiin A , 1
Lcd A
Enable Interrupts
Return
pleas!!!!!!!!
