hemnath
Advanced Member level 3
I have the output from Mosfet Source pin as +3V. I'm trying to boost this +3V to +5V using LM2623. But the problem is,
when i connect mosfet of Source to input to LM2623. Voltage at source pin (which is +3V) drops to 0.7V and at the output of the LM2623 is 1.1V.
Then, i have disconnected the mosfet source pin and LM2623.
I have applied external voltage from a voltage source to +3V to input of LM2623. In this case, output from the LM2623 is +5V, looks good.
What could be the problem? I think it may be due to higher impedance? If it's, how to make it to higher impedance to lower impedance.
Please help!!!
Please help!!!
