Neil_Preston
Newbie level 3
I've build a microstrip antenna with a probe feed. I've manufactured the antenna and decided to build a matching circuit. I've taken the antenna s-parameters from the network analyzer and put it into ADS. Then I've build a lumped matching circuit using a matching tool. After that I've replaced the calculated values with the closest values based on manufacturer's datasheets. After that I've manufactured the matching PCB circuit. However the results didn't match and now I'm trying to figure what's wrong. Maybe it's because I used a barrel interconnector to connect two female sma's. However, I don't know how can I get rid of it. Maybe there is a way I can integrate the probe into the circuit, like cutting the connector and soldering the pin to the circuit.
Hope you can help.
Thanks,
Neil
Hope you can help.
Thanks,
Neil
