[SOLVED] "Power" operator with LUT exponent
clros
Member level 2
Hi to all,
I have a problem with Quartus II (Altera),that depends on my poor knowledge of vhdl.
This code:
type lut_array_type is array(3 downto 0) of std_logic_vector(5 downto 0);
signal myLUT : lut_array_type ;
myLUT(0)<="10011";
myLUT(1)<="11011";
myLUT(2)<="10010";
myLUT(3)<="10101";
result <= (2**myLUT(0));
I have an error on last row; "... can't determine definition of operator ""**"" -- found 0 possible definitions"
Why? Can you help me?
What makes you think that ** operator is defined for integer ** std_logic_vector?
For a complete question, you need to specify the imported libraries and definition of result.
As far as I'm aware of, ** isn't synthesizable, power of two can be however represented by SHL operator, with argument types supported by the respective libraries.
I had not thought about the fact that it also depended on the type of arguments.
In my example I included:
[B]library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;[/B]
If I use an integer LUT, apparently it works fine.
But is it also possible to use a power with bases different from 2?
Quartus will tell you that it's not synthesizable. You can implement it as repeated multiply, of course only useful for small exponents or in a pipelined design.
What do yo want to achieve? Under circumstances, it's better to use a precalculated table of powers.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
entity pwr is port(
   exp   : in  integer range 0 TO 3;
   base  : in  integer range 0 TO 3;
   result: out integer range 0 to 31
end pwr;
architecture rtl of pwr is
function power(base: integer; exp: positive; bound: positive) return integer is
variable temp: integer;
begin
   temp := 1;
   for i in 1 to bound loop
      if i <= exp then
         temp := base*temp;
      end if;
   end loop;
   return temp;
end;
begin
   result <= power(base, exp, exp'high);
end;
Reactions: clros
    clros
