power amplify until 500V and input 4Mhz
annise045132
Newbie level 3
is there any power amplify with that specification...
i've just received suggest that ishould use igbt (insulated gate bipolar transistor) to solve this problem. but when i see the datasheet for igbt, it says that the input is only receive for 1 Mhz.
may i know about power amplifier is...? maybe there is a limitation to make this power amplifier?
thank you... ^_^
I think you can also design it with power MOSFETS, there are high voltage MOSFETS which are moderately fast.
