[SOLVED] port 0 problem on at89c52 with lcd ??
#MAAM#
Full Member level 2
Egypt
Hi guys
When i interface LCD(2x16) (4 bit mode) with at89c52 in port 3 it work well. when i connect it to port 0 (by taking into account i change the code with port 0) it is not working !!!!!!!
my working code with port 3
basic calculator.c
#include <reg52.h>
#include "lcd.h"
main( )
    LCD_init();
    LCD_row1(); LCD_putc(0+48);//LCD_puts("Hello World");
    LCD_row2(); LCD_puts("Good Morning");
    while (1);
lcd.h
 sbit LCD_en =P3^7;
 sbit LCD_rs =P3^5;
 sbit rw =P3^6;
 #define LCD_DELAY 1535 /* Delay for 1 ms */
 #define LCD_clear() LCD_command(0x1)	/* Clear display LCD */
 #define LCD_origin() LCD_command(0x2)	/* Set to origin LCD */
 #define LCD_row1() LCD_command(0x80)	/* Begin at Line 1 */
 #define LCD_row2() LCD_command(0xC0)   /* Begin at Line 2 */
 * Prototype(s)                                    *
void LCD_delay(unsigned char ms);
void LCD_enable();
void LCD_command(unsigned char command);
void LCD_putc(unsigned char ascii);
void LCD_puts(unsigned char *lcd_string);
void LCD_init();
 * Sources                                         *
	unsigned char n;
	unsigned int i;
	for (n=0; n<ms; n++)
		for (i=0; i<LCD_DELAY; i++); /* For 1 ms */
void LCD_enable()
    LCD_en = 0; /* Clear bit P2.4 */
    LCD_delay(1);
    LCD_en = 1; /* Set bit P2.4 */
    LCD_rs = 0; /* Clear bit P2.5 */
    P3 = (P3 & 0xF0)|((command>>4) & 0x0F);
    LCD_enable();
    P3 = (P3 & 0xF0)|(command & 0x0F);
    LCD_enable();
    LCD_delay(1);
    LCD_rs = 1; /* Set bit P2.5 */
    P3 = (P3 & 0xF0)|((ascii>>4) & 0x0F);
    LCD_enable();
    P3 = (P3 & 0xF0)|(ascii & 0x0F);
    LCD_enable();
    LCD_delay(1);
	while (*lcd_string)
		LCD_putc(*lcd_string++);
void LCD_init()
	rw=0;
    LCD_command(0x33);
    LCD_command(0x32);
    LCD_command(0x28);
    LCD_command(0x0C);
    LCD_command(0x06);
    LCD_command(0x01); /* Clear */
    LCD_delay(256);
my not working code with port 0
basic calculator.c
#include <reg52.h>
#include "lcd.h"
main( )
    LCD_init();
    while (1);
lcd.h
 sbit LCD_en =P0^7;
 sbit LCD_rs =P0^5;
 sbit rw =P0^6;
 * Prototype(s)                                    *
void LCD_enable();
void LCD_init();
 * Sources                                         *
	unsigned char n;
	unsigned int i;
void LCD_enable()
    LCD_delay(1);
    P0 = (P0 & 0xF0)|((command>>4) & 0x0F);
    LCD_enable();
    P0 = (P0 & 0xF0)|(command & 0x0F);
    LCD_enable();
    LCD_delay(1);
    P0 = (P0 & 0xF0)|((ascii>>4) & 0x0F);
    LCD_enable();
    P0 = (P0 & 0xF0)|(ascii & 0x0F);
    LCD_enable();
    LCD_delay(1);
	while (*lcd_string)
void LCD_init()
	rw=0;
    LCD_command(0x33);
    LCD_command(0x32);
    LCD_command(0x28);
    LCD_command(0x0C);
    LCD_command(0x06);
    LCD_delay(256);
i upload my project file including code & proteus simulation file. thanks in advance
  • basic calculator.rar
put a pullup resistor on Port 0..
Reactions: #MAAM#
    #MAAM#
You have to connect Pull at P0 otherwise it will not work
you get Resistor network of 8 resistors its 9pin component connect common pin to VCC and rest 8 pins to each port 0 pin
Reactions: #MAAM#
    #MAAM#
thanks... it works with me well now
thanks for your advice
check if the data changes in port0... just to confirm port is working fine............
thanks the solution is to put a pull up resistor as mentioned before.
