plot gain and phase margin in cadence
sykab
Member level 2
Member level 2
ac analysis break loop
Hi!
I’m trying to design, in Cadence, a single-ended CMOS AMPOP and I need to make a ac analysis. Actually, I’m using this schematic as a test bench‘s. Is that right? The problem is that I don’t know what kind of vin should I specify for my analysis:?:
Furthermore, I would like to ask if someone can give me or advice me some kind of information/book about simple single-ended CMOS AMPOP 0,35 µm.
Thanks!:cry:[/b]
how to do ac analysis of opamp
The input is the nonreverse terminal .The R1 must remove.
    sykab
opamap ac test setup
In Cadence, you can use stb analysis to do AC simulation.
    sykab
ac analysis example for opamp
Thanks for your reply. But I have another problem.
The input sinal (vin) should be a vsin. But, I have no idea what amplitude and frequency should I specify :cry:
Thanks
ac analysis of op amp
what type of sources do you have?
are you confused bw vsin and vac?
it depends what type of test you want to do.
    sykab
op amp ac analysis
The voltage supply is 5 V and I want an opamp with a Bandwidth of 100 MHz.
This opamp will be used in a current source with the specifications indicated in the image. I'm thinking to design a simple OTA. Is it a good choice?
Furthermore, I have no idea which amplitude and frequency I should define in the vin (vsin) sinal in the test bench's.
op amp ac analysis example
Are you trying to get a loop gain plot like bode plot ? If that is what you want, you should add an AC test signal or "iprobe" into the feedback loop. Please refer to the following link.
As for R1, is there any simulation problem like no dc path from your inverting node to gnd if you remove R1. For more details, it is probably helpful to visit
https://www.analog.com/UploadedFiles/Application_Notes/1023068910AN_937.pdf
    sykab
nmos ac analysis, cadence
Yes, I'm trying to get a bode plot.
Re: AC analysis of an OPAMP
If you are trying to do an ac analysis, then I dont understand the need of a sine source. Give a DC voltage some where in middle of ICMR and on that ac voltage of 1v. I mean the VIN should be defined like : vinp vin gnd 1.2 ac 1v.
here 1.2 is the dc voltage and 1v is the magnitude of the ac signal.
you dont need to specify the frequency of signal... its job of simulator to sweep the freq and plot the gain and phase.
I cadence environment you can directly use the Y element. no need to specify the ac signal even.
    sykab
At first, thanks for your reply.
It's the first time that I'm using Cadence and I don't know what's "Y element".
Hi ,
Y element is just another form of iprobe... or putting more simply its something that trie to implement the middlebrook method of feedback loop analysis, without bothering about the point at which to break the loop. If you dont have Y element with ur suite then go for iprobe, and if even thats not available then refer to the ken kundurts paper metioned earlier in this thread.
    sykab
You should apply a common mode signal say 1.2v (dc) to the differential pair. it will also have Vin+ and Vin- ac inputs. This common mode signal is necessary to drive the diff. pair and set the voltage Vx, where the tail current source is connected, Typically Nmos. Bias for this nmos will be computed using the simple equation of saturation of transistor Vgs - Vth < Vds.
Thus the Common mode stage sets your voltage Vx, such that current gets divided equally in both arms of the diff pair.
Hope this helps.
    sykab
Try Jacob Baker's book, first edition. Also your setup is unity gain set up. Try this way, output is fedback through a big resistor, like 100M to the negative input, then connect a 10uF cap to the negative input.
    sykab
