rrumpf
Full Member level 5
- Joined
- Jul 6, 2007
- Messages
- 294
- Helped
- 66
- Reputation
- 132
- Reaction score
- 43
- Trophy points
- 1,308
- Location
- El Paso, TX
- Activity points
- 3,624
I am quite new to PLL design and analysis and have what I hope is a simple question to somebody.
I am developing a system that will use a PLL to track the resonant frequency of a small micro-beam around 26 kHz. I would like retrieve the frequency to within 0.01 Hz resolution. Using canned formulas in the literature and text books, my "lock in" time, or the response time due to a step change in frequency, should be less than one second.
This seems to violate the Uncertainty principle from signal theory which states the more we try to "locate" a signal in frequency, the less we can locate it in time. Stated another way, to resolve a frequency to 0.01 Hz resolution should take a system much more than one second. An approximate formula can be written:
dt * df > 0.5
where df is the frequency resolution and dt is the time resolution.
I am trying to reconcile the "lock in" time or "pull in" time formulasfor PLLs with the Uncertainty principle and they seem to contradict each other. Any guidance anyone could provide would be greatly appreciated. Remember I am a novice PLL person!!
Thanks!!
-Tip
dt * df > 0.5
Thanks!!
-Tip
