maniana
Member level 4
I am looking for a solution for MIMO RF front-end.
Normal PLL will lock the RF to the reference but if you have several PLLs using the same reference the RF frequencies will have a random phase (RF to RF).
What I need is a PLL chip or a few of them that lock the RF frequency to the reference and I need the generated RF frequencies to be in phase with each other.
The first idea was to split the RF signal into several paths, but in this case all front-ends can only work at the same frequency.
My preference is to be able to run some of the front-ends at different frequencies. However when I tune all the front-ends to the same RF frequency I want all the RF phases to be the same. We are planning to have 5-7 antennas. RF frequency range DC to as high as possible, however for now we don't need more than 1GHz. One chip doesn't have to cover the whole range.
Can anyone suggest a solution?
