please check this problem no erroprs not getting results
chaitanya.531
plz
check this code
this give no errors on xilinx but results showing uuuuuu or xxxxxx
THIS IS TEST BENCH OF A PROGRAM DECRYPTION
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use STD.TEXTIO.all;
use IEEE.STD_LOGIC_TEXTIO.all;
entity RC5_DECRYPT_TB is
    generic ( T        : time   := 10 ns ;
              infile   : string := "C:\Xilinx\kcha\rc5_DECRYPT_tb.in";
              outfile  : string := "C:\Xilinx\kcha\rc5_DECRYPT_tb.out";
              keyfile  : string := "C:\Xilinx\kcha\rc5_DECRYPT_tb.key" );
end entity;
architecture test of RC5_DECRYPT_TB is
	COMPONENT RC5_DECRYPT_TOP
	PORT(
		clk : IN std_logic;
		ken : IN std_logic;
		ski : IN std_logic_vector(32 downto 1);
		di : IN std_logic_vector(64 downto 1);
		do : OUT std_logic_vector(64 downto 1)
	END COMPONENT;
    signal clk       : std_logic:='0';
    signal ski       : std_logic_vector(32 downto 1);
    signal enable    : std_logic := '0';
    signal ciphertxt : std_logic_vector(32*2 downto 1);
    signal plaintxt  : std_logic_vector(32*2 downto 1) := (others=>'0');
    file kfp : text open read_mode  is keyfile;
    file ifp : text open read_mode  is infile;
    file ofp : text open write_mode is outfile;
    constant D : time := 1 ns;
begin -- architecture
  uut: RC5_DECRYPT_TOP PORT MAP(
          	clk => clk,
            ken => enable,
            ski => ski,
            di  => ciphertxt,
            do  => plaintxt
    -- process to generate clock signal
    process
    begin
        clk <= not clk;
        wait for T/2;
    end process;
    -- process to set up subkeys
    process
        variable L : line;
        variable bv1 : std_logic_vector(32 downto 1);
    begin
        wait for 10*T;
        enable <= '1' after D;
        for i in 0 to 26-1 loop
            readline(kfp,L); -- read subkey from file
            read(L,bv1);
            wait until rising_edge(clk);
            ski <= bv1 after D; -- send to RC5_DECRYPT_TOP
        end loop;
        enable <= '0' after D;
        wait; -- halt this process
    end process;
    -- encrypt some  ciphertxt words from the input file
    process
        variable L : line;
        variable bv : std_logic_vector(32*2 downto 1);
    begin
        wait until enable='1';
        wait for (26+20)*T;
        while not endfile(ifp) loop
            readline(ifp,L);
            read(L,bv); -- read plaintext bit vector
            write(L,plaintxt);
            writeline(ofp,L);
            ciphertxt  <= bv after D;
        end loop;
            write(L,plaintxt); writeline(ofp,L);
       wait;
    end process;
end test;
AND RESULTS GETTING IS
I THINK PROBLEM IN THE FILE I/O COMMNADS
file are given as attchments
PLZ HELP
  • files.rar
I have not used the language you are using but I program in BASIC.
I have observed that calling file I/O routines, or spreading file reading commands among more than one function, can change or reset some things.
Additionally, anything you do that is timing-dependent may be overruled as file I/O takes place at its own speed and its own convenience.
Best to do all file I/O at one time, or at moments when your program is not doing cpu-intensive operations.
brad - this is not the case in vhdl.
there is nothing wrong with the file IO, the problem is inside decrypt component.
