Please,Anyone could help me in timing constraint error ?
adam_lo
Newbie level 6
Hello,
Please, I need help so much.
I don't now why when I add my custom ip core .this error appeared.
what this error mean?
and how to solve it ?
Partition Implementation Status
No Partitions were found in this design.
NGDBUILD Design Results Summary:
Number of errors: 0
Number of warnings: 108
Writing NGD file "system.ngd" ...
Total REAL time to NGDBUILD completion: 22 sec
Total CPU time to NGDBUILD completion: 21 sec
Writing NGDBUILD log file "system.bld"...
NGDBUILD done.
# Starting program map
# map -o system_map.ncd -pr b -ol high -timing -detail system.ngd system.pcf
Release 12.1 - Map M.53d (nt64)
Copyright (c) 1995-2010 Xilinx, Inc. All rights reserved.
PMSPEC -- Overriding Xilinx file <E:/ISSe/ISE_DS/EDK/data/Xdh_PrimTypeLib.xda>
with local file <E:/ISSe/ISE_DS/ISE/data/Xdh_PrimTypeLib.xda>
Using target part "3sd3400afg676-4".
Mapping design into LUTs...
WARNING:LIT:176 - Clock buffer is designated to drive clock loads. BUFGMUX
symbol
"physical_group_clk_125_0000MHzDCM0/clock_generator_0/clock_generator_0/DCM0_
CLK0_BUFG_INST" (output signal=clk_125_0000MHzDCM0) has a mix of clock and
non-clock loads. The non-clock loads are:
Pin I0 of
DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_s3_ddr2_phy.mpmc_phy_if_0/infrastructur
e/cal_top/tap_dly/gen_no_sim.l0
Writing file system_map.ngm...
Running directed packing...
Running delay-based LUT packing...
Updating timing models...
ERROR:pack:1653 - At least one timing constraint is impossible to meet because
component delays alone exceed the constraint. A timing constraint summary
below shows the failing constraints (preceded with an Asterisk (*)). Please
use the Timing Analyzer (GUI) or TRCE (command line) with the Mapped NCD and
PCF files to identify which constraints and paths are failing because of the
component delays alone. If the failing path(s) is mapped to Xilinx components
as expected, consider relaxing the constraint. If it is not mapped to
components as expected, re-evaluate your HDL and how synthesis is optimizing
the path. To allow the tools to bypass this error, set the environment
variable XIL_TIMING_ALLOW_IMPOSSIBLE to 1.
For more information about the Timing Analyzer, consult the Xilinx Timing
Analyzer Reference manual; for more information on TRCE, consult the Xilinx
Command Line Tools User Guide "TRACE" chapter.
INFO:Timing:3284 - This timing report was generated using estimated delay
information. For accurate numbers, please refer to the post Place and Route
timing report.
Asterisk (*) preceding a constraint indicates it was not met.
This may be due to a setup or hold violation.
Constraint | Check | Worst Case | Best Case | Timing | Timing
| | Slack | Achievable | Errors | Score
* TS_clock_generator_0_clock_generator_0_SI | SETUP | -1.864ns| 17.864ns| 19| 16212
G_DCM0_CLKDV = PERIOD TIMEGRP "clock_gene | HOLD | 0.134ns| | 0| 0
rator_0_clock_generator_0_SIG_DCM0_CLKDV" | | | | |
TS_sys_clk_pin / 2 HIGH 50% | | | | |
NET "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/ge | MAXDELAY | 0.090ns| 0.100ns| 0| 0
n_s3_ddr2_phy.mpmc_phy_if_0/data_path/dat | | | | |
a_read_controller/gen_dqs[2]..u_dqs_delay | | | | |
_col0/delay4" MAXDELAY = 0.19 ns | | | | |
_col0/delay1" MAXDELAY = 0.19 ns | | | | |
_col0/delay2" MAXDELAY = 0.19 ns | | | | |
_col1/delay5" MAXDELAY = 0.19 ns | | | | |
_col1/delay3" MAXDELAY = 0.19 ns | | | | |
_col1/delay4" MAXDELAY = 0.19 ns | | | | |
_col1/delay1" MAXDELAY = 0.19 ns | | | | |
_col1/delay2" MAXDELAY = 0.19 ns | | | | |
a_read_controller/gen_dqs[1]..u_dqs_delay | | | | |
_col0/delay5" MAXDELAY = 0.19 ns | | | | |
a_read_controller/gen_dqs[0]..u_dqs_delay | | | | |
_col0/delay3" MAXDELAY = 0.19 ns | | | | |
a_read_controller/gen_dqs[3]..u_dqs_delay | | | | |
NET "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/ge | MAXDELAY | 0.430ns| 0.100ns| 0| 0
n_s3_ddr2_phy.mpmc_phy_if_0/infrastructur | | | | |
e/cal_top/tap_dly/tap<7>" MAXDELAY = 0.53 | | | | |
ns | | | | |
e/cal_top/tap_dly/tap<15>" MAXDELAY = 0.5 | | | | |
3 ns | | | | |
e/cal_top/tap_dly/tap<23>" MAXDELAY = 0.5 | | | | |
3 ns | | | | |
NET "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/ge | MAXDELAY | 0.600ns| 0.100ns| 0| 0
n_s3_ddr2_phy.mpmc_phy_if_0/dqs_int_delay | | | | |
_in<0>" MAXDELAY = 0.7 ns | | | | |
_in<1>" MAXDELAY = 0.7 ns | | | | |
_in<2>" MAXDELAY = 0.7 ns | | | | |
_in<3>" MAXDELAY = 0.7 ns | | | | |
TS_clock_generator_0_clock_generator_0_SI | SETUP | 1.835ns| 4.869ns| 0| 0
G_DCM0_CLK0 = PERIOD TIMEGRP "clock_gener | HOLD | 0.438ns| | 0| 0
ator_0_clock_generator_0_SIG_DCM0_CLK0" T | | | | |
S_sys_clk_pin HIGH 50% | | | | |
NET "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/ge | MAXDELAY | 1.900ns| 0.100ns| 0| 0
n_s3_ddr2_phy.mpmc_phy_if_0/data_path/fif | | | | |
o_1_wr_en<3>" MAXDELAY = 2 ns | | | | |
o_1_wr_en<2>" MAXDELAY = 2 ns | | | | |
o_1_wr_en<1>" MAXDELAY = 2 ns | | | | |
o_1_wr_en<0>" MAXDELAY = 2 ns | | | | |
o_0_wr_en<3>" MAXDELAY = 2 ns | | | | |
o_0_wr_en<0>" MAXDELAY = 2 ns | | | | |
o_0_wr_en<1>" MAXDELAY = 2 ns | | | | |
o_0_wr_en<2>" MAXDELAY = 2 ns | | | | |
TS_clock_generator_0_clock_generator_0_SI | SETUP | 2.578ns| 2.844ns| 0| 0
G_DCM0_CLK90 = PERIOD TIMEGRP "clock_gene | HOLD | 0.552ns| | 0| 0
rator_0_clock_generator_0_SIG_DCM0_CLK90" | MINLOWPULSE | 5.036ns| 2.964ns| 0| 0
TS_sys_clk_pin PHASE 2 ns HIGH 50% | | | | |
NET "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/ge | MAXDELAY | 2.900ns| 0.100ns| 0| 0
a_read_controller/rst_dqs_div" MAXDELAY = | | | | |
3 ns | | | | |
a_read_controller/.rst_dqs_div_delayed/de | | | | |
lay2" MAXDELAY = 3 ns | | | | |
lay1" MAXDELAY = 3 ns | | | | |
lay4" MAXDELAY = 3 ns | | | | |
lay3" MAXDELAY = 3 ns | | | | |
lay5" MAXDELAY = 3 ns | | | | |
TS_sys_clk_pin = PERIOD TIMEGRP "sys_clk_ | SETUP | 7.006ns| 0.994ns| 0| 0
pin" 125 MHz HIGH 50% | HOLD | 0.704ns| | 0| 0
| MINLOWPULSE | 3.200ns| 4.800ns| 0| 0
Derived Constraint Report
Review Timing Report for more details on the following derived constraints.
To create a Timing Report, run "trce -v 12 -fastpaths -o design_timing_report design.ncd design.pcf"
or "Run Timing Analysis" from Timing Analyzer (timingan).
Derived Constraints for TS_sys_clk_pin
| | Period | Actual Period | Timing Errors | Paths
Analyzed |
| Constraint | Requirement
| | | Direct | Derivative | Direct | Derivative | Direct |
Derivative |
|TS_sys_clk_pin | 8.000ns| 4.800ns| 8.932ns| 0| 19| 3|
492225|
| TS_clock_generator_0_clock_gen| 8.000ns| 4.869ns| N/A| 0| 0| 5422|
0|
| erator_0_SIG_DCM0_CLK0 | | | | | | |
| TS_clock_generator_0_clock_gen| 8.000ns| 2.964ns| N/A| 0| 0| 980|
0|
| erator_0_SIG_DCM0_CLK90 | | | | | | |
| TS_clock_generator_0_clock_gen| 16.000ns| 17.864ns| N/A| 19| 0| 485823|
0|
| erator_0_SIG_DCM0_CLKDV | | | | | | |
1 constraint not met.
Mapping completed.
See MAP report file "system_map.mrp" for details.
Problem encountered during the packing phase.
Please, Realy I need your help so..... much
thanks in advance
Regards
Adam
Go to timing report and see which path is getting failed and analyze the path delays...
