Planar tranformer - help me in understanding the subject
elexlearner
Junior Member level 3
India
tranformer
Hi ,
I want to design a planer transformer for an AC-DC flyback convertor (about 1W)
can anybody help me with design note or an ebook to help me in understanding the subject.
Thanks,
planar transformer 1w
why planar transformer for 1W ??? they are suitable for hundereds of watts, where the space is a big issue, required efficiency is high, and reliability.
take a look at paytongoup. they have some application notes: **broken link removed**
Planar tranformer
Of course you can design planar transformers for a few watt, e.g using ER9.5 core. You have to find out the specific advantages and disadvantages yourself. I remember that Ferroxcube had some application notes, but basically, you should be able to calculate all relevant parameters, as for wire wound transformers. Small planar transformers make sense, when you can integrate them in an existing PCB, but unfortunately, the stackup requirements are rather different for standard PCB and planar transformers. For low power and signal transformers, the performance drawbacks (e.g. low fill factor) can be acceptable.
All the best i will try to help you if i find some thing related to your project.
