Placement of pole at origin for buckboost feedback compensation?
T
treez
Dr Ridley, in his book, "power supply design", volume 1 , control, states on page 73 that regarding using a type 2 compensator for a buckboost, "the first pole of the compensator is placed at the origin to form an integrator"
However, in the attached type 2 compensator, the first pole is f = 1/[2.pi.R1(C1+C2)]......and this cannot be placed at the origin (f=0) unless either R1 or (c1+c2) is made infinite, which is nonsensical.
Do you know what is meant ?
  • Type 2_tim dom.pdf
When you have a 1/s term in your transfer function, it is clearly a pole at the origin. However, how can you put it in your bode plot when you have a frequency scale of powers of 10. You can put this pole in your bode diagram at location frequency f=1 at 0 dB. Below 1, the value 1/s is increasing to the left 20dB/dec. For f higher than 1, the bode plot is decreasing steadily -20dB/dec. It is similar to when you have a C/s term which is a pole at the origin where C is a constant. You can draw it on your bode diagram as a slant line with slope -20dB/dec passing through the point f=C at 0dB.
In your case, C = 1/[2.pi.R1(C1+C2)].
Reactions: treez
    T
The circuit has two poles, one of which is at the origin. A brief glance should be sufficient to show this (infinite gain at DC).
And R1 does not affect any pole or zero frequencies (just the K).
Reactions: treez
    T
