kotsam
PIC24FJ128GA010 Stuck
Hi EveryBody ,
I designed simple system using PIC24FJ128GA010 , which can write several lines on LCD and these lines can be controlled by switches , more over I have some LEDs’ controlled by the pic and brightness can be controlled from the pic using PWM , I’m using internal oscillator . at the beginning the system worked just perfect , I had the chance to debug my code to solve all the code problem . then I took the code to burn it to another similar PCB and its not working anymore, so I find out that the PIC stuck when I run the code . the running tool shows that code is running but when I click at halt it show me error message of the debug mode. I tried without the debug mode and still the pic stuck . could the problem be in my configuration ?
Hi EveryBody ,
