PIC18f46k22 not working
Hayee
Hi everyone.
I was using PIC18F452 microcontroller for my project and now I am shifting to PIC18F46K22 microcontroller.
I am wondering why I am not able to use PORTS as an input/output in this microcontroller except PORTB.
I am using MPLAB XC8 compiler.
Below is my Code. Could you guys look at this and tell me if something is wrong there
C:
void main() {
    TRISBbits.TRISB0 = 1;
    TRISBbits.TRISB3 = 0;
    TRISBbits.TRISB4 = 0;
    TRISDbits.TRISD5 = 1;
    TRISCbits.TRISC2 = 0;
    TRISDbits.TRISD0 = 0;
    while(1)
        PORTBbits.RB4 = !PORTBbits.RB4;// Toggle the LED
        PORTCbits.RC2 = !PORTCbits.RC2;// Toggle the LED
        PORTDbits.RD0 = !PORTDbits.RD0;// Toggle the LED
        __delay_ms(100);
        if(PORTBbits.RB0){
            PORTBbits.RB3 = 1;// LED ON
            while(PORTBbits.RB0);
            PORTBbits.RB3 = 0;// LED OFF
        if(PORTDbits.RD5){
            PORTBbits.RB4 = 1;// LED ON
            while(PORTDbits.RD5);
            PORTBbits.RB4 = 0;// LED OFF
also here is the FUSES settings
// CONFIG1H
#pragma config FOSC = HSHP   // Oscillator Selection bits (Internal oscillator block)
#pragma config PLLCFG = OFF     // 4X PLL Enable (Oscillator used directly)
#pragma config PRICLKEN = OFF   // Primary clock enable bit (Primary clock can be disabled by software)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRTEN = ON     // Power-up Timer Enable bit (Power up timer disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
#pragma config BORV = 190       // Brown Out Reset Voltage bits (VBOR set to 1.90 V nominal)
// CONFIG2H
#pragma config WDTEN = OFF      // Watchdog Timer Enable bits (Watch dog timer is always disabled. SWDTEN has no effect.)
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = PORTC1  // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF     // PORTB A/D Enable bit (PORTB<5:0> pins are configured as digital I/O on Reset)
#pragma config CCP3MX = PORTB5  // P3A/CCP3 Mux bit (P3A/CCP3 input/output is multiplexed with RB5)
#pragma config HFOFST = ON      // HFINTOSC Fast Start-up (HFINTOSC output and ready status are not delayed by the oscillator stable status)
#pragma config T3CMX = PORTC0   // Timer3 Clock input mux bit (T3CKI is on RC0)
#pragma config P2BMX = PORTD2   // ECCP2 B output mux bit (P2B is on RD2)
#pragma config MCLRE = EXTMCLR  // MCLR Pin Enable bit (MCLR pin enabled, RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF        // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection Block 0 (Block 0 (000800-003FFFh) not code-protected)
#pragma config CP1 = OFF        // Code Protection Block 1 (Block 1 (004000-007FFFh) not code-protected)
#pragma config CP2 = OFF        // Code Protection Block 2 (Block 2 (008000-00BFFFh) not code-protected)
#pragma config CP3 = OFF        // Code Protection Block 3 (Block 3 (00C000-00FFFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection Block 0 (Block 0 (000800-003FFFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection Block 1 (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF       // Write Protection Block 2 (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF       // Write Protection Block 3 (Block 3 (00C000-00FFFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection Block 0 (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection Block 1 (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection Block 2 (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection Block 3 (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#define _XTAL_FREQ 20000000
@betwixt still unable to read the PIN's, however I used the LAT bits to output and uptill now it is working. But these LAT registers are in every microcontroller like I am using PIC18f452 but I never use the LAT register. I simply use PORTxbits.Rx4 to read and write to PIN.
why it is so?
The reason for using the LAT registers instead of just writing to the port is to avoid what we call the "RMW" (Read Modify Write) problem. On PIC devices, if you change a single bit on a port, it reads the whole port data (8 bits) into the core, changes the bit then writes the whole port data back. If you imagine you are only changing one bit, the other 7 bits are also read and they are written back along with the one you changed. You are writing a snapshot of the pins, changing it and writing it back, the state of the pins may not be what you expect at the time of taking the snapshot.
The LAT registers are latches, they separate the reading and writing circuits to avoid the problem.
I can't see anything obviously wrong in you code, so you might have a hardware problem. You have the MCLR pin enabled, do you have it pulled high?
Actually the hardware is same. as PIC18f452 and PIC18F46K22 are pin compatible I replace 452 with 46k22. In 452 input and output working fine. but in 46k22 it is not.
Yes MCLR is pulled high.
Inputs are analogue by default. You need to changed inputs to digital for your application
Button de-bounce is missing.
Here is my attempt:
C:
// random code found on forum
// desperately needs button de-bounce code added
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
void main() {
    ANSELB = 0;                                             // all digital
    ANSELC = 0;                                             // all digital
    ANSELD = 0;                                             // all digital
    TRISBbits.TRISB0 = 1;                                   // B0 input for button
    TRISBbits.TRISB3 = 0;                                   // B3 output for LED
    TRISBbits.TRISB4 = 0;                                   // B4 output for LED
    TRISDbits.TRISD5 = 1;                                   // D5 input for button
    while(1)
        LATBbits.LATB4 = !LATBbits.LATB4;                   // Toggle the LED
        LATCbits.LATC2 = !LATCbits.LATC2;                   // Toggle the LED
        LATDbits.LATD0 = !LATDbits.LATD0;                   // Toggle the LED
        __delay_ms(100);
        if(PORTBbits.RB0){                                  // wait button press
            LATBbits.LATB3 = 1;                             // LED ON
            __delay_ms(100);                                // crude way to de-bounce button
            while(PORTBbits.RB0);                           // wait for end of button press
            LATBbits.LATB3 = 0;                             // LED OFF
        if(PORTDbits.RD5){
            LATBbits.LATB4 = 1;                             // LED ON
            LATBbits.LATB4 = 0;                             // LED OFF
LaTeX Commands Quick-Menu:
