Linspire
Full Member level 5
Hi guys,
I have tested successfully for Keypad 4x4 by referring the MikroC user manual keypad library coding.
I did test on 7Hz only which trigger interrupt and fed into CLKIN as clock signal.
However, I found out when I use HS mode, 20Mhz to run testing, it seem the coding doesn't working properly.
Does anyone here can suggest idea how to solve this ?
Linspire
Linspire
