PIC18F4520 & MikroC & Keypad 4x4
Linspire
Full Member level 5
M'sia
Hi guys,
I have tested successfully for Keypad 4x4 by referring the MikroC user manual keypad library coding.
I did test on 7Hz only which trigger interrupt and fed into CLKIN as clock signal.
However, I found out when I use HS mode, 20Mhz to run testing, it seem the coding doesn't working properly.
Does anyone here can suggest idea how to solve this ?
Regards
Linspire
Ok.Here 's the mikroC keypad library example codes:
unsigned short kp, cnt, oldstate = 0;
char txt[6];
// Keypad module connections
char  keypadPort at PORTD;
// End Keypad module connections
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
void main() {
  cnt = 0;                                 // Reset counter
  Keypad_Init();                           // Initialize Keypad
  //ANSEL  = 0;                              // Configure AN pins as digital I/O
  //ANSELH = 0;
  ADCON1 = 0x0F;
  CMCON = 0x07;
   TRISB = 0;
   PORTB = 0xFF;
// dodaj da se iskljuce komparatori
  Lcd_Init();                              // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);                     // Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF);                // Cursor off
  Lcd_Out(1, 1, "Key  :");                 // Write message text on LCD
  Lcd_Out(2, 1, "Times:");
  do {
    kp = 0;                                // Reset key code variable
// Wait for key to be pressed and released
    do
    //  kp = Keypad_Key_Press();           // Store key code in kp variable
        kp = Keypad_Key_Click();           // Store key code in kp variable
    while (!kp);
// Prepare value for output, transform key to it's ASCII value
    switch (kp) {
      case  1: kp = 49; break; // 1
      case  2: kp = 50; break; // 2
      case  3: kp = 51; break; // 3
      case  4: kp = 65; break; // A
      case  5: kp = 52; break; // 4
      case  6: kp = 53; break; // 5
      case  7: kp = 54; break; // 6
      case  8: kp = 66; break; // B
      case  9: kp = 55; break; // 7
      case 10: kp = 56; break; // 8
      case 11: kp = 57; break; // 9
      case 12: kp = 67; break; // C
      case 13: kp = 42; break; // *
      case 14: kp = 48; break; // 0
      case 15: kp = 35; break; // #
      case 16: kp = 68; break; // D
    if (kp != oldstate) {                  // Pressed key differs from previous
      cnt = 1;
      oldstate = kp;
    else {                                 // Pressed key is the same as previous
      cnt++;
    Lcd_Chr(1, 10, kp);                    // Print key ASCII value on LCD
    if (cnt == 255) {                      // If counter variable overflow
      cnt = 0;
      Lcd_Out(2, 8, "   ");
    ByteToStr(cnt, txt);                   // Transform counter value to string
    Lcd_Out(2, 8, txt);                   // Display counter value on LCD
  } while (1);
Linspire
---------- Post added at 22:34 ---------- Previous post was at 21:15 ----------
Anyone can suggest solution or opinion to solve this ?
Linspire
