PIC18F26K22 interrupt problem
UroBoros
Advanced Member level 2
Cochin - India
I am trying to make a interrupt driven code on this chip. I am using timer 0 and timer 6 here. This is my initialization code for timer 6 and interrupt. The overflow flag is getting set as expected. I can it polled positive in mainline also. The timing is also happening as expected. But simply interrupt is not throwing. what is I am missing here?
Timer0 code is giving interrupts as expected, but timer 6 is not vectoring to ISR on overflow.
//for 1ms - 1 clock cycle 15.625nSec @ 64Mhz. 1 instruction cycle 62.5nS.
//Prescalar 16, postscalar 4 and reload value 250 will give 1ms interrupt
void Timer6_ini(void)
T6CON = 0b00011011;
TMR6=0;                         //Clear Timer
PR6=250;                         //Reload value for 1ms
PIR5bits.TMR6IF=0;            //Timer6 flag cleared(2nd bit 0 clear)
IPR5bits.TMR6IP=0;            //Timer6 interrupt on low priority(2nd Bit - 0)
PIE5bits.TMR6IE=1;            //Timer6 interrupt enabled(2nd bit enabled)
PMD0bits.TMR6MD=0;        //Timer6 module not disabled
T6CONbits.TMR6ON = 1;    //Enable the timer.
void EnableInterrupts(void)
RCONbits.IPEN=1;            // interrupt priority enabled (7tH bit)
INTCONbits.GIE=1;        //global interrupt  enabled
INTCONbits.PEIE=1;            // all interrupts enabled
Nop();
Thanks
Those 2 functions are seems to be ok. may be something wrong in your main code.
How did you called them ?
did you clear interrupt flag after working on it ?
How did you check the code ? simulator or debugger ?
This is the mainline code
#pragma code HIGH_INTERRUPT_VECTOR = 0x08
	void High_ISR (void)
	{						// If you are using this programe hex file with a conventional
	  	_asm goto YourHighPriorityISRCode _endasm	//device programmer this directives will help
	#pragma code LOW_INTERRUPT_VECTOR = 0x18
	void Low_ISR (void)
	  	_asm goto YourLowPriorityISRCode _endasm
//---------------------------------------------------------------End of re-direction-----------------
void main(void)
	Delay10KTCYx(2);
	ports_ini();
	Timer0_ini();
	Timer4_ini();
	Timer5_ini()	;
	Timer6_ini();
	EnableInterrupts();// two times
	lcd_ini();
	PORTCbits.RC2=1;
	Delay_Ms(100);
	PORTCbits.RC2=0;
	Delay_Ms(150);
	PORTCbits.RC2=1;
	Delay_Ms(100);
	PORTCbits.RC2=0;
	lcdstringptr(EmbCkit,1);
	lcdstringptr(USBMicro,2);
	lcdstringptr(CurCount,3);
	lcdstringptr(Digitis,4);
	while(1)
				PORTC |=0b00000011;
				PORTB |=0b00011111;
				Delay1KTCYx(250);
				PORTC &= 0b11111100;
				PORTB &= 0b11100000;
				Delay1KTCYx(250);
				if(INTCONbits.TMR0IF)
						INTCONbits.TMR0IF=0;
						_asm nop _endasm
				if(PIR5bits.TMR4IF)
						PIR5bits.TMR4IF=0;
						_asm nop _endasm
				if(PIR5bits.TMR6IF)
						PIR5bits.TMR6IF=0;	//I am getting flag set here on all timers
						_asm nop _endasm
				if(PIR5bits.TMR5IF)
						PIR5bits.TMR5IF=0;
						_asm nop _endasm;
Here is the interrupt code. I placed the traps in both high and low priority vectors
//Here we starts the real interrupt code!
#pragma code InterruptFunctions
//------------------This is the actual interrupt functions---------------------------------------------------------------------------------
#pragma interrupt YourHighPriorityISRCode//08h
void YourHighPriorityISRCode()
		//Here we can insert any high priority interrupt code if required
			if(PIR5bits.TMR6IF)
				PIR5bits.TMR6IF=0;
				_asm nop _endasm
				_asm nop _endasm
		if(PIR5bits.TMR4IF)
				PIR5bits.TMR4IF=0;
				_asm nop _endasm
		if(PIR5bits.TMR5IF)
				PIR5bits.TMR5IF=0;
				_asm nop _endasm;
		_asm nop _endasm
	}	//This return will be a "retfie fast", since this is in a #pragma interrupt section
#pragma interruptlow YourLowPriorityISRCode//18h
void YourLowPriorityISRCode()
		if(PIR5bits.TMR6IF)
				PIR5bits.TMR6IF=0;
				_asm nop _endasm
				_asm nop _endasm
		if(PIR5bits.TMR4IF)
				PIR5bits.TMR4IF=0;
				_asm nop _endasm
		if(PIR5bits.TMR5IF)
				PIR5bits.TMR5IF=0;
				_asm nop _endasm;
I am testing on MPLAB SIM and on MPLB ICD2. in both cases result same.
Thanks for the time
For any interrupt of timers that you have used; will it correctly jump to interrupt vector ?
Will it jump to YourHighPriorityISRCode() or YourLowPriorityISRCode() ?
(Although you have same code on both locations)
Check you declaration; is it according to syntax ?
void Low_ISR (void)
Yes. Timer0 behaves as expected- in timing and reaching proposed locations , clearing the flag and reappears at the expected time again in ISR.
T6CON = 0b00011011
means you have selected 1:4 postscaler, can you change it to 1:1 as below,
T6CON = 0b00000011
and check when first matching of TMR6 and PR6 occur, program branch to interrupt.
Still only Timer 0 vectors to interrupt.
I have attached this test project which can be opened in MPLAB installed with MPLABC18 and compile. If somebody can throw some light into this problem, it will be helpful.
Thanks
  • TestLedBlink.rar
I can't check the code in MPLABC at the moment.
When you debug the program, will you see TMR6 register increase and when it match to PR6, TMR6IF goes high ?
If yes, at the moment TMR6=PR6; watch interrupt enable bits
Global interrupts / Low priority interrupts / Interrupt for timer6;
May be some other interrupt masking the timer6 interrupt.
