Interrupt priorities
Hayee
Member level 2
Hi
I am working on interrupts and without settings the priorities of interrupts the code is working fine. following is the code without defining priority of TIMER3 interrupt.
C:
void __interrupt() ISR(void){
    //===Timer3 Interrupt Routine============================================//
     * Timer3 is used to create a 1 Sec delay.
     * This 1 Sec delay can be used by different tasks.
    if(PIR2bits.TMR3IF){
        _1sec++;
        if(_1sec == 10)
            RED_LED = !RED_LED;    // Toggle LED after every sec
            if(backlight_timeout) backlight_timeout--;
            if(serial_timeout) serial_timeout--;
            _1sec = 0;
        PIR2bits.TMR3IF = 0;
        TMR3H = 0x3C;
        TMR3L = 0xB0;
but when i assign low priority to the interrupt it does not works, I also defined the IP flag for Timer3
IPR2bits.TMR3IP = 0; // Timer3 Interrupt: Low Priority
code for low priority
C:
void __interrupt(__low_priority) LowPriorityISR(void){
    if(PIE2bits.TMR3IE && PIR2bits.TMR3IF){
        _1sec++;
        if(_1sec == 10)
            RED_LED = !RED_LED;
            _1sec = 0;
        TMR3H = 0x3C;
        TMR3L = 0xB0;
I am using MPLAB XC8 compiler version 6.15 and microcontroller is PIC18f46k22
Kindly guide me what is wrong or missing in the code
LaTeX Commands Quick-Menu:
