pic16f EUSART problem in RF link
biswajitdas49
Member level 3
WEST BENGAL,INDIA
Recently I am doing a project on RF link using PIC16F1936 EUSART. So first I started with simple Eusart code, only a Tx send a 8bit data(eg B'01010101') through 433Mhz RF transmitter at 9600bps baud and a RF receiver receive it and decode the 8bit data through pic uc thats it. Here the problem start, when I check portb of rx uC with LED, I found which bit value is 1 that glows well but which containing 0 bits are blinking. But when I connect both this uC Tx and Rx pin with a wire that worked fine as I want and also my 433MHz Tx-Rx pair works fine with HT12E and HT12D but I don't want to use HT12E & D.
So I don't understand what's wrong with my code, or do I need any necessary changes in my code.
PLEASE somebody help me to solve this, I think this will be very helpfull for others too...
Thanks,
Tx code is here-
;   This file is a basic code template for code generation on the             *
;   PIC16F1936. This file contains the basic code building blocks to build    *
;   upon.        *
;   Refer to the MPASM User's Guide for additional information on             *
;   features of the assembler.                                                *
;   Refer to the respective data sheet for additional                         *
;   information on the instruction set.                                       *
;    Filename:        xxx.asm                                                 *
;    Date:        *
;    File Version:                                                            *
;    Author:        *
;    Company:        *
;    Files Required: P16F1936.INC                                             *
;    Notes:        *
;    Revision History:                                                        *
	list		p=16f1936      ; list directive to define processor
	#include	<p16f1936.inc> ; processor specific variable definitions
; CONFIGURATION WORD SETUP
; The 'CONFIG' directive is used to embed the configuration word within the
; .asm file. The lables following the directive are located in the respective
; .inc file.  See the data sheet for additional information on configuration
; word settings.
    __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_ON & _IESO_OFF & _FCMEN_OFF
    __CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_19 & _LVP_OFF
; VARIABLE DEFINITIONS
; Available Data Memory divided into Bank 0-15.  Each Bank may contain
; Special Function Registers, General Purpose Registers, and Access RAM
    CBLOCK 0x20 ; Define GPR variable register locations
        ADC_TEMP
        CounterA  ;
        MYVAR3  ;
    ENDC
SAMPLE1        EQU    0x7D        ; Sample user registers
SAMPLE2        EQU    0x7E        ;
SAMPLE3        EQU    0x7F        ;
; EEPROM INITIALIZATION
; The 16F1936 has 256 bytes of non-volatile EEPROM, starting at address 0xF000
DATAEE    ORG  0xF000
    DE    "MCHP"  ; Place 'M' 'C' 'H' 'P' at address 0,1,2,3
; RESET VECTOR
    ORG     0x0000            ; processor reset vector
    PAGESEL START
    GOTO    START             ; When using debug header, first inst.
                              ; may be passed over by ICD2.
; INTERRUPT SERVICE ROUTINE
    ORG      0x0004
; USER INTERRUPT SERVICE ROUTINE GOES HERE
; Note the 16F1936 family automatically handles context restoration for
; W, STATUS, BSR, FSR, and PCLATH where previous templates for 16F families
; required manual restoration
    RETFIE                    ; return from interrupt
; MAIN PROGRAM
START
	BANKSEL OSCCON
	MOVLW B'01111010'
	MOVWF OSCCON			;Fosc 16MHz
	BANKSEL PORTA
	BCF PORTA,0
	BANKSEL LATA
	BCF LATA,0
	BANKSEL ANSELA
	BSF ANSELA,0				;ANALOG INPUT AN0(PIN 2)
	BANKSEL TRISA
	BSF TRISA,0
	BANKSEL TRISC
	BCF TRISC,6		;TX
	BSF TRISC,7		;RX
	BSF TRISC,0
	BANKSEL PORTC
	BCF PORTC,6		;TX (pin 17)
	BCF PORTC,7		;RX (pin 18)
	BCF PORTC,0
	BANKSEL ADCON1		;A/D CONTROL REGISTER 1
	BSF ADCON1,ADFM		;A/D Result Format Select bit(RIGHT JUSTIFIED)
	BCF ADCON1,ADCS2		;A/D Conversion Clock Select bits
	BSF ADCON1,ADCS1		;IS Fosc/32
	BCF ADCON1,ADCS0
	BCF ADCON1,ADNREF	;VREF- is connected to AVSS
	BCF ADCON1,ADPREF1	;VREF+ is connected to AVDD
	BCF ADCON1,ADPREF0
	BANKSEL ADCON0
	MOVLW B'00000001'
	MOVWF ADCON0
	BANKSEL SPBRGH
	CLRF SPBRGH
	BANKSEL SPBRG
	MOVLW .25
	MOVWF SPBRG
	BANKSEL BAUDCON		;BAUD RATE CONTROL REGISTER
	MOVLW B'00001000'	;16-bit Baud Rate Generator bit
	MOVWF BAUDCON
	BANKSEL TXSTA		;TRANSMIT STATUS AND CONTROL REGISTER
	MOVLW B'00100100'	;set Transmit Enable bit,High Baud Rate Select bit
	MOVWF TXSTA
	BANKSEL RCSTA		;RECEIVE STATUS AND CONTROL REGISTER
	MOVLW B'10010000'	;set Serial Port Enable bit,Continuous Receive Enable bit
	MOVWF RCSTA
HERE1
;	CALL DELAY
;	BANKSEL ADCON0
;	BSF ADCON0,GO 		;Start conversion
;	BTFSC ADCON0,GO 		;Is conversion done?
;	GOTO $-1
;	BANKSEL ADRESL
;	MOVF ADRESL,W
;	BANKSEL ADC_TEMP
;	MOVWF ADC_TEMP
SEND_USART
	BANKSEL TXREG
	MOVLW B'01010101'				;B'01010101'
	MOVWF TXREG
	BANKSEL TXSTA
	BTFSS TXSTA,TRMT		;Transmit Shift Register is full(0) or empty(1)
	GOTO $-1
GOTO HERE1
DELAY
	movlw D'131'
	movwf CounterA
loop
	decfsz CounterA,F
	goto	loop
	retlw 0
    END
Rx code is here-
;   upon.        *
;    Date:        *
;    File Version:                                                            *
;    Author:        *
;    Company:        *
;    Notes:        *
; word settings.
        MYVAR1  ; User variables allocated contiguously
        MYVAR2  ;
        MYVAR3  ;
    ENDC
SAMPLE2        EQU    0x7E        ;
SAMPLE3        EQU    0x7F        ;
DATAEE    ORG  0xF000
; RESET VECTOR
    PAGESEL START
    ORG      0x0004
; MAIN PROGRAM
START
	BANKSEL OSCCON
	MOVLW B'01111010'
	BANKSEL TRISC
	BCF TRISC,6		;TX
	BSF TRISC,7		;RX
	BANKSEL PORTC
	BCF PORTC,6		;TX
	BCF PORTC,7		;RX
	BANKSEL PORTB
	CLRF PORTB
	BANKSEL ANSELB
	CLRF ANSELB
	BANKSEL TRISB
	CLRF TRISB
	BANKSEL INTCON
	BSF INTCON,PEIE
	BSF INTCON,GIE
	BANKSEL SPBRGH
	CLRF SPBRGH
	BANKSEL SPBRG
	MOVLW .25
	MOVWF SPBRG
	MOVWF BAUDCON
	MOVLW B'00100100'
	MOVWF TXSTA
	BANKSEL RCSTA
	MOVLW B'10010000'
	MOVWF RCSTA
HERE
	BANKSEL PIR1
	BTFSS PIR1,RCIF
	GOTO $-1
	BANKSEL RCREG
	MOVF RCREG,W
	BANKSEL PORTB
	MOVWF PORTB
GOTO HERE
    END
When your bit is '1' the transmitter is turned on and the receiver picks it up.
When your bit is '0' the transmitter is turned off - consider what the receiver is then picking up. It will be random noise, possibly with other 433MHz transmissions mixed in with it.
Brian.
To maximize the throughput of a ASK/OOK TX/RX pair, you will need to implement an appropriate encoding scheme, such as Manchester encoding. Details of this benefit are discussed in the thread recommended by FvM and other threads posted on this forum. Also, a baud rate of 9600 bps is most likely over optimistic, the range of 1200 or 2400 bps is more realistic.
