#include<pic18.h>
#include"pic_lcd8.h"
void main()
TRISD=0x00;
TRISC=0X00;
Lcd8_Init();
Lcd8_Display(0x80,"PIC18F452 TESTIN",16);
Delay(500);
while(1)
Lcd8_Display(0x80,"................",16);
Delay(500);
while(1);
#include<pic18.h>
#pragma config WDT = OFF
void main()
TRISD=0x00;
TRISC=0X00;
Lcd8_Init();
Delay(500);
while(1)
Delay(500);
while(1);
thanks all....
the led having no role in the circuit ....as i mensioned the problem is regarding resetting the circuit. the last ""while(1);""statement is used to terminate the program.
but, it is not terminating there and again executing the code.
#define First_Line 0x80
#define Second_Line 0xc0
#define Curser_On 0x0f
#define Curser_Off 0x0c
#define Clear_Display 0x01
#define Data_Port PORTD
static bit Lcd_rs @((unsigned) &PORTC*8+4);
static bit Lcd_en @((unsigned) &PORTC*8+5);
void Lcd8_Init();
void Lcd8_Command(unsigned char);
void Lcd8_Write(unsigned char,unsigned char);
void Lcd8_Display(unsigned char,const unsigned char*,unsigned int);
void Lcd8_Decimal2(unsigned char,unsigned char);
void Lcd8_Decimal3(unsigned char,unsigned char);
void Lcd8_Decimal4(unsigned char,unsigned int);
void Delay(unsigned int);
void Lcd8_Init()
Lcd8_Command(0x38); //to select function set
Lcd8_Command(0x06); //entry mode set
Lcd8_Command(0x0c); //display on
Lcd8_Command(0x01); //clear display
void Lcd8_Command(unsigned char com)
Data_Port=com;
Lcd_en=1;
Lcd_rs=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Write(unsigned char com,unsigned char lr)
Lcd8_Command(com);
Data_Port=lr; // Data
Lcd_en=1;
Lcd_rs=1;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Display(unsigned char com,const unsigned char *word,unsigned int n)
unsigned char Lcd_i;
for(Lcd_i=0;Lcd_i<n;Lcd_i++)
Lcd8_Write(com+Lcd_i,word[Lcd_i]);
void Lcd8_Decimal2(unsigned char com,unsigned char val)
unsigned int Lcd_hr,Lcd_t,Lcd_o;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_t+0x30);
Lcd8_Write(com+1,Lcd_o+0x30);
void Lcd8_Decimal3(unsigned char com,unsigned char val)
unsigned int Lcd_h,Lcd_hr,Lcd_t,Lcd_o;
Lcd_h=val/100;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_h+0x30);
Lcd8_Write(com+1,Lcd_t+0x30);
Lcd8_Write(com+2,Lcd_o+0x30);
void Lcd8_Decimal4(unsigned char com,unsigned int val)
unsigned int Lcd_th,Lcd_thr,Lcd_h,Lcd_hr,Lcd_t,Lcd_o;
val = val%10000;
Lcd_th=val/1000;
Lcd_thr=val%1000;
Lcd_h=Lcd_thr/100;
Lcd_hr=Lcd_thr%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_th+0x30);
Lcd8_Write(com+1,Lcd_h+0x30);
Lcd8_Write(com+2,Lcd_t+0x30);
Lcd8_Write(com+3,Lcd_o+0x30);
void Delay(unsigned int del)
while(del--);
