PI Controler with Limiter
pancho_hideboo
Advanced Member level 5
Real Homeless
See attached figure.
I think this is basically PI Controler with Limiter.
Here difference of input and ouput of Limiter is fed back to integral input.
What effect can I expect from this feedback ?
It's an anti-windup circuit that clamps the integrator output at the actual limits of the manipulated value.
I think, it's called anti-windup back calculation method.
This should have no impact on the bode plot but in some of these special cases should make the system come out of saturation more gracefully. I only see this coming into play in a couple instances.
First if the limit changes while the system is saturated it would correct the integrator accordingly.
Second if its a large system with a lag time between the PI controller and the system component that detects the limit. In this case the 'extra' windup can be backed out.
EDIT: Third if the system takes large steps and may jump well over a limit.
Any others?
I design systems with such a lag because I design generic controllers whose output needs to be scaled etc before going to a modulator block which understands and applies limits. There are a handful of clock delays in this path which allow the integrators to wind up a little extra. Though I haven't seen evidence it causes problems.
