talent_engin
Newbie level 2
Hi all,
I am running an exitsing verilog code using Synopsys Design Compiler (version 2006 or 2009 or 2010). The code containing several parameterized modules that caused the following warnings when I link the design:
Warning: Cannot find the design 'secret_number' in the library 'WORK'. (LBR-1)
Warning: Unable to resolve reference 'secret_number' in 'testing'. (LINK-5)
The original code is sth like this:
//This is the reference module
module secret_number
#(parameter WIDTH = 5)
(input [WIDTH-1:0] WE,
output [WIDTH-1:0] QE);
endmodule
//this module calls a secret_number module:
module testing (IN, OUT);
input IN;
output OUT;
secret_number #(5) S1
.WE (),
.QE ()
endmodule
I have checked the syntax used to initiate a parameterized module in Verilog. There are a few ways:
1. Using defparam
2. Using the #(Parameter_valule_list) form
3. Using the #(.Parameter(value)) form.
None of these works for me. The thing is if I call the module without passing a new parameter value (i.e. in the above code, I remove #(5)), the code works perfectly normal.
When I pass a new value to the module, It cannot be resolved.
Any one knows what's going on here? and how to solve this.
Thanks a million.
endmodule
input IN;
output OUT;
.WE (),
.QE ()
endmodule
1. Using defparam
Thanks a million.
