PADS 2007 Spiral Traces
Farooq0520
Newbie level 6
Newbie level 6
I am running a single trace, and wan to run in spiral but the straight trace and then an arc for the same trace since this is a round board. then next loop will be 2 degrees off from the 1st loop for the straight portion. Go through a via, and then do same thing on bottom side and go to a connector. Basically will be working a coil.
I am having difficulty setting the angle and arc for same trace with 5 mil trace and 5mill gap. Anyone know this? There will be 4 quadrant like this, if anyone can help, i can evens end the file and see if it can be done.
OK, i will try, have you ever tried something like this router?
Do you know how to have an angled traces at 3 degrees from one trace to another? I don't know how it can be done in 2007, i can only change to AA(any angle mode) but can't find a way to put 3 degrees?
