pepewaw
Newbie level 6
I'm designing the last stage of a PA which is to operate at 700MHz (around 50Mhz bandwidth) at 10W. Due to availability, It´s convinient to use the BLF544, which according to the datasheet can be made into a 960Mhz 20W PA.
However, looking at the S parameters downloaded from NXP (which are listed below)
@700MHz
S11 = 0.895 177°
S21 = 0.392 7.5°
S12 = 0.0603 -60°
S22 = 0.875 -170°
I find S21 being too small to get any significant gain, yet, according to the MSG formula, it says that theorically I could theorically obtain around 9dB gain.
My questions are:
+ how much of this theorical value can I expect to achieve in practice?
+ I´ve tried matching the input and output for maximun power transfer (complex conjugate impedances); is this the correct way to achieve maximun gain?
+ Every time i match the output, it mismatches the input, and Vice versa. Is there a recomended procedure/steps to follow to avoid this?
Thanks for any tips
PS: Just in case it's necessary, the input and output impedances are 50Ohms.
@700MHz
S11 = 0.895 177°
S21 = 0.392 7.5°
S12 = 0.0603 -60°
S22 = 0.875 -170°
My questions are:
Thanks for any tips
