ruben91
Junior Member level 3
I have fix my code to test Hc-Sr04 sensor and its working fine, but there is one problem i'm facing now. which is the output(LED) is not light up as bright as it should even without resistor, but it is very dim. Even i test with voltmeter it shows 5v in the output pin. But when i test it with buzzer, the buzzer keeps buzzing, I don't know where i went wrong, Pls help me with this, any help is much appreciated
#include<p18f1330.h>
#include<delays.h>
#include <math.h>
#pragma config WDT=OFF
#pragma config OSC=INTIO2
#pragma config PWRT=ON
unsigned int a;
unsigned int time;
void main()
OSCCONbits.IRCF2 = 1;// 4mhz OSC
OSCCONbits.IRCF1 = 1;//
OSCCONbits.IRCF0 = 0;//
TRISBbits.TRISB4=0; // trig
TRISBbits.TRISB5=1; //echo
TRISAbits.TRISA2=0; //RED led
TRISAbits.TRISA3=0; //GREEN led
while(1)
PORTBbits.RB4=0;
PORTBbits.RB5=0;
PORTAbits.RA2=0;
PORTAbits.RA3=0;
TMR1H= 0;
TMR1L= 0;
PORTBbits.RB4=1;
Delay10TCYx(1);
PORTBbits.RB4=0;
while(PORTBbits.RB5 == 0); //If ECHO is HIGH
T1CONbits.TMR1ON = 1; //Start Timer
while(PORTBbits.RB5 == 1); //If ECHO is LOW
T1CONbits.TMR1ON = 0; //Stop Timer
// a = (TMR1L | (TMR1H<<8))/58.82; //Calculate Distance
//Delay10KTCYx(255);
time= TMR1H;
time= time<<8;
time= time|TMR1L;
a = time/58;
PIR1bits.TMR1IF=0;
Delay10TCYx(60);
if(a<=400)
PORTAbits.RA2=1; //red
if(a<=2000)
//PORTAbits.RA3=1; //green
LATAbits.LATA3=1;
