lebronic
Junior Member level 1
Onebit Add/Sub using 8051-HELP
Hello Friends:
i'm trying to do one bit simple calc(using 8051 MCU) , which can take two numbers and operator from the Keyboard (save the numbers in RAM)
then do the math
the problem i'm facing , i end up having wrong numbers when reading from RAM .
here's my asm code:
Any help would be appreciated
Hello Friends:
then do the math
here's my asm code:
ORG 000H
JMP MAIN
ORG 003H
JMP INT0
ORG 100H
MAIN:
MOV A,#78H
p1: MOV P1,#0FFH
MOV IE,#10000001B
CLR IT0
MOV R0,#0
JMP $
ZERO: CJNE R0,#00H,ONE
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
ONE: CJNE R0,#01H,TWO
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
TWO:
CJNE R0,#02H,THREE
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
THREE:
CJNE R0,#03H,FOUR
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
FOUR:
CJNE R0,#04H,FIVE
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
FIVE:
CJNE R0,#05H,SIX
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
SIX:
CJNE R0,#06H,SEVEN
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
SEVEN:
CJNE R0,#07H,EIGHT
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
EIGHT: CJNE R0,#08H,NINE
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
NINE: CJNE R0,#09H,AA
POP A
MOV R1,A
MOV A,R0
MOV @R1,A
MOV P2,R0
MOV A,R1
INC A
SETB EA
RETI
AA: CJNE R0,#0AH,BB
MOV R1,78H
MOV A,79H
ADD A,R1
MOV P2,A
SETB EA
RETI
BB:
CJNE R0,#0BH,FINISH
MOV R1,78H
MOV A,79H
SUBB A,R1
MOV P2,A
SETB EA
RETI
FINISH:
RETI
DELAY:
MOV R5,#5
DL2:
MOV R6,#200
DL1:
MOV R7,#249
DJNZ R7,$
DJNZ R6,DL1
DJNZ R5,DL2
RET
INT0:
CLR EA
PUSH A
MOV A,P1
ANL A,#00001111B
MOV R0,A
JMP ZERO
SETB EA
RETI
