ON measuring circular polarization antenna
ljx1067
Junior Member level 1
In the book it is said that :"the rate of the linear probe antenna is much greater than the rotation rate of the test antenna "So what is the actual rotate rate of the two antenna? How much can be called greater?
and what about the data recorder rate?
