nabla101
Junior Member level 3
I want to transmit and receive a short (300ps) gaussian pulse for use in a time of flight RF distance measurement scheme (Which has a UWB, bandwidth of 3.3GHz?)
I want a transceiver to be able to transmit the pulse to another transceiver, which can then retransmit the pulse (With a known delay) back to the original transceiver, which calculates the round trip time.
I have seen a system using an omnidirectional broadband planar monopole antenna as the transmitter, and a directional vivaldi antenna array as the receiver (Has to be pointed towards the transmitter), however, it is important in my application to have a single omnidirectional antenna for each transceiver, which can be used as transmitters and receivers, and I so I want to know if this can be acheived with the broadband planar monopole antenna design, or if not, which type of antenna I can use to acheive this.
I have limited expertise in this field so please go easy.
Cheers
Cheers
