tinska.h
Junior Member level 2
Greetings,
Can someone point out what are the methods to transmit simultaneously/asynchronously between many slaves or nodes to the host, by using only one conductor?
For example, in I2C, master uses address to select which slave can transmit data. Or SPI uses CS to select which slave to communicate. How can one transfer data without addressing or chip selects? Howabout in Power Line Communications, assumingly there are multiple nodes that want to transmit data to another, how can each node determine when to transmit the data without packet collisions? Or is it always controlled by a host?
Is there ANY methods to transmit data over single conductor (+ground of course) without the need of host telling the clients/slaves when to transmit, or who is able to transmit?
I'm very new in the communications area, so any advice or pointers are more than welcome.
Thanks in advance!
- Tinska
Thanks in advance!
- Tinska
