negative DC power regulator?
winglj
Full Member level 4
dc regulator circuit for negative
Hi, everyone.
I am wondering whether you guys have any recommendations for negative DC power, convert -5V to -3V? Thanks.
negative dc
Check LM79x series .
    winglj
Hai winglj
Just try out the variable voltage regulator LM137 which will regulate any voltage from -1.2 volts to -27volts. The said device is complimentary to LM317 which is a posetive voltage regulator. Hope it helps You. Please do not forget the "Helped me" button. Good luck.
    winglj
