- Joined
- Jul 4, 2009
- Messages
- 16,261
- Helped
- 5,140
- Reputation
- 10,309
- Reaction score
- 5,124
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 137,625
I'm only at the initial stages of gathering information to find the optimum solution for this but ideas from others would be welcomed. This is the rather unusual situation:
I've got about 1.5KW of PV generation here, currently feeding a grid-tied inverter to offset electricity company bills. I also have an unusual load situation where one or two pumps may be intermittently operating with a load of about 1.5KW each. This is as well as 'normal' domestic use which sits at around 350W most of the day but reaches peaks of about 6KW. It works fine as it is and the PV helps to keep the bills down. I cannot re-sell electricity to the grid so making an income from excess production isn't possible, however this isn't an issue.
The problem is the incoming AC supply (230V) is liable to frequent interruptions, possibly lasting for days. With the PV being grid-tied, when the incoming power fails, the anti-islanding kicks in and also stops the PV feed. It's a commercialy made inverter and I don't want to reverse engineer it to fake incoming power when there isn't any, and it would be illegal to do so anyway.
I have a 5KW Diesel backup generator which gets used when the grid is off but it has a mechanical speed governor which is slow to react to load changes, hence the grid-tied inverter drops out every time it senses a frequency change on the line. So although I have power from the generator, I can't simultaneously use the PV to augment it.
Faster regulation of the generator speed isn't really a feasible solution, even with near instantaneous fuel control, the mass of the motor and generator wouldn't keep it stable enough. So I'm looking at electrical solutions. My first thoughts are to build a hefty PWM inverter, maybe rated at 10KW but rather than feed it from low voltage DC, to simply hang a bridge rectifier on the output of the generator so I would have around 340V DC ahead of the PWM switches. A crystal controlled PWM inverter would be stable enough for the PV to continue working. I can forsee some problems, in particular the likely chances of the PV back-driving the PWM output.
Has anyone experience of doing this kind of thing?
Brian.
Brian.
