Need Support to design
samson.bunty1986
Member level 5
Dear all,
Kindly suggest me how to design the driving circuit forthis charge controller?? How to vary the duty cycle here?? Please can anyone help me out...
From this circuit i will replace the diode with mosfets to convert to inverter later.. Am planning to design charge controller as well as inverter from the same circuit..
Kindly anyone helpme in doing this..
Regards,
Samson
  • Lead Acid Battery Charger.PDF
I think you need to learn VHDL-AMS language. In this language you can design the desired deisgn. Click on the following link for VHDL-AMS tutorial:
Can any one help here. i want to design a power inveretr using a 555 timer, i want to increse the amperes and i want to cascade the transistors for incresing the amperes. is it possible.
is the image
