Need help to convert code to show voltage as X,XX and not as XX,X
ggmssr
This is LED voltmeter with 3 digit and all works fine in format xx,xV. Today I need to measure up to 9,99V and how I can change source code to make this? Resolution its nice to sense 10mV. PIC is 16f676.
Code is here
#include <htc.h>
__CONFIG (FOSC_INTRCIO & MCLRE_OFF & BOREN_ON & CP_OFF & CPD_OFF & WDTE_OFF & PWRTE_ON );
#define SPORT PORTA
#define DPORT PORTC
const char SegCode[11] = {0x40,0x57,0x22,0x06,0x15,0x0C,0x08,0x56,0x00,0x04,0xFF};
	//                       0    1    2    3    4    5    6    7    8    9
const char Column[3]   = {0x02,0x01,0x04};
static char Segment[3] = {0x7f,0x7f,0x7f};
static unsigned char ColCount=0x00;
void CPU_SETUP(void);
void Display(void);
void HTO7S(unsigned int Num);
void delayMs(int x);
unsigned int result;
unsigned int readAdc(void);
void interrupt  timer1_isr(void)
if(PIR1bits.TMR1IF==1)
PIR1bits.TMR1IF = 0;
	TMR1H=0xDF;
Display();
void main()
	unsigned char i;
	CPU_SETUP();
	while(1)
		result=0;
		for (i=0;i<3;i++)
			delayMs(1);
			result=result+readAdc();
				HTO7S(result/3);
		delayMs(200);
void CPU_SETUP()
	CMCON =0x07;		//Turn off comparator module
	ANSEL =0x8;			//AN3 as analog input
	ADCON1 =0x60; 		//clock/64
	ADCON0 = 0x8D;
   	TRISA=0b00011000;
   	PORTA=0x27;
   	TRISC=0b00000000;
   	PORTC=0x37;
   T1CON= 0x00;
  	TMR1H=0xDF;
   	INTCONbits.GIE =1;
	INTCONbits.PEIE=1;
	PIE1bits.TMR1IE =1;
 	T1CONbits.TMR1ON=1;
unsigned int readAdc()
unsigned int res;
ADCON0bits.GO_DONE =1;
while(ADCON0bits.GO_DONE ==1);
res=ADRESL+(ADRESH*0x100);
return(res);
// Display routine
void Display()
	PORTA = 0b00100111;	  // off all digits column and Segment G
	PORTC = 0b00111111;   // off segment a-f
	if (ColCount>=3)
	ColCount=0;
	DPORT = Segment[ColCount];
	SPORT = ((Segment[ColCount] & 0b01000000)>>1) | (Column[ColCount]^0x07);
	ColCount++;
// Convet HEX 2 byte to 7-Segment code
	unsigned int res;
	res = ((30*Num)%1023)/100;
	if(res==10)
	Num=Num+1;
	res=0;
	Segment[2]=SegCode[res];
	res = (30*Num)/1023;
	Segment[1]=SegCode[res%10];
	Segment[0]=SegCode[res/10];
	if (Segment[0]==0x40)
	Segment[0]=0xFF;
void delayMs(int x)
int i;
for (x ;x>0;x--)
for (i=0;i<=110;i++);
I hope that is ok if I post this short post, and that will pass without warnings.
I make first two digits, first number and first decimal, but for 2 decimal I cannot find solution.
	unsigned int res;
	res = ((9*Num)%1023)/100;
	 if(res==10)
	 Num=Num+1;
	 res=0;
	Segment[1]=SegCode[res];
	res = (9*Num)/1023;
	Segment[0]=SegCode[res];
	// if (Segment[0]==0x40)
	// Segment[0]=0xFF;
If I understand correctly you are trying to convert the ADC result (0-1023) to a voltage representation as ASCII.
You seem to be mixing the conversion steps which messes things up.
First calculate the ADC voltage , use
voltage = adc_result * Vref / 1023;   // for 10bit ADC
Then convert the voltage to ASCII
voltage=1234;
char lcd[6];
lcd[0]=voltage/1000;		// first digit
lcd[1]=(voltage/100) % 10;	// second digit
lcd[2]=(voltage/10) % 10;	// third digit
lcd[3]=(voltage) % 10;		// fourth digit
lcd[0] +='0'; convert integer to ASCII;
lcd[1] +='0'; convert integer to ASCII;
lcd[2] +='0'; convert integer to ASCII;
lcd[3] +='0'; convert integer to ASCII;
//the result will be "1234"
or
voltage=1234;
char lcd[6];
lcd[2]='.';					// dot
lcd[3]=(voltage/10) % 10;	// third digit
lcd[4]=(voltage) % 10;		// fourth digit
lcd[4] +='0'; convert integer to ASCII;
//the result will be "12.34"
For different ADC ranges change the code accordingly
Reactions: ggmssr
    ggmssr
if you dont mind plz explain the whole code , i am a beginner in embedded field, I am also searching for a code for measuring voltage.
This code from first post is for 7-seg LED display, and works with 3 7-seg digit, all works fine for voltage range from 0 to 30V in format 30,0 25,3 13,8 7,3 ... and I want now to modify this code to measure up to 9,99 with two decimals, and if possible to increase resolution, I think now is around 45mV for 3-digit. It will be fine that new code can sense second decimal for Li-Ion battery 4,21 3,95 3,74 ....
dp led on 7-seg is connected always in original circuit on second digit, now will be on first digit.
I thought it was for LCD :roll:
still I think you can use the code I have provided and just ignore the last lines that convert the digit to ASCII.
For example
voltage=123;
Segment[0]=(voltage/100) % 10;	// first digit
Segment[1]=(voltage/10) % 10;	// second digit
Segment[2]=(voltage) % 10;		// third digit
Reactions: ggmssr
    ggmssr
I dont have success.
This code works but only for first two digits, and I cant adjust third.
	res = (9*Num)/1023;
	res = ((9*Num)/1023);
For this code I get >
voltage is 7,93 and on display i get 797
For this code >
	res = (9*Num)/1023;
	res = ((9*Num)%1023)/1000;
Voltage is 7,93 and on display I get 790
for this code I get 008 on display and voltage is 7,93
	res = (9*Num)/1023;
	res = ((9*Num)%1023)/10;
I'm not sure what you are doing in your code , what I suggested is
Calculate the voltage from the ADC result using
What is your Vref , is it 5v?
What is the resolution of the ADC , is it 10bit (0-1023)?
If so then you can use
unsigned int voltage=0;
voltage = adc_result * (unsigned long)5000 / 1023;   // for 10bit ADC, using Vref=5000mV, result in mV
Segment[0]=(voltage/1000);	// first digit
Segment[1]=(voltage/100) % 10;	// second digit
Segment[2]=(voltage/10) % 10;		// third digit
