armghan11
Member level 1
I am a ccs c compiler user but unfortunately have some problems with burning ccs c code with genius programmer.. so i am trying to convert my ccs c code to mikroc as mikroc works perfect with g540. i need little help with timers. here is
my ccs timer2 function:
and here is initializing commands and prescaler i used in void main:
Please help me to convert this ccs code to mikro c
#int_TIMER2
void TIMER2_isr(void) //interrupt handler for timer
char i;
count++;
if(count==250) //i.e 1 sec = 245 count at 4Mhz
sec++;
count=0;
if(sec==60)
{min[0]++;
sec=0;
if(min[0]==1)
disable_interrupts(INT_TIMER2);
for(i=1;i<5;i++)
if(load[i]) //time update here
//TimeUpdate(i);
min[i]++;
if(min[i]==60)
hour[i]++;
//saves time value in eeprom
write_eeprom(50,hour[1]);
write_eeprom(51,min[1]);
write_eeprom(52,hour[2]);
write_eeprom(53,min[2]);
write_eeprom(54,hour[3]);
write_eeprom(55,min[3]);
write_eeprom(56,hour[4]);
write_eeprom(57,min[4]);
min[0]=0;
enable_interrupts(INT_TIMER2);
return;
void main()
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_64);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_2(T2_DIV_BY_16,255,1);//4ms per interrupt
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
enable_interrupts(GLOBAL);
