zafir
Member level 1
Hellow everyone, I have to use fluxgate magnetometer with one excitation and one sense coil for measuring earth's magnetic field in only one axis.I don't know how this sensor works and I don't have any circuit for it.I require an output dc voltage which increases when the sensor is aligning with the earth's northpole and decrease when sensor is aligning with the southpole.Moreover if some how, output voltage is also the function of strength of magnetic field then this would be much more helpful for me.At the end side I will use matlab to calculate magnetic field using world Magnetic model(WMM) or any other model.PLease post any link,circuit,pdf or anything related to this topic.I first require an interfacing circuit between sensor and adc.Thanx for your time.
Best Regards,
Zafir
Best Regards,
Zafir
