[SOLVED] Need GLCD Blue Colour Data Sheet For 18 PIN (JHD12864C-C3_D091201)
sacban
Junior Member level 3
Dear All,
Today I just received my GLCD Blue Colour with 18 Pin , order from Electronics Online Store in My Country.
I have searching for this GLCD to internet following on the back (board) JHD12864C-C3_D091201, but I am still not sure with the information.
Below is the specification from the Store :
LCD 128X64 C BLUE
Graphic LCD 128x64 pixel type STN negative transmissive (blue) with white LED backlight
Spesification :
- Power Supply : Typical 5 VDC
- Interface : Paralel 8-bit
- Total Dot : 128 x 64 dots
- Type of LCD : STN
- Backlight : white
- Controller : KS0107-KS0108 controller or equivalent.
- View area : 62,0 (W) x 44,0 (H) mm
- Dimension : 78,0 (W) x 70,0 (H) x 14,3 (T) mm (outline)
As well an information I have on internet........please refer to my attached document (1 pdf & 1 jpg).
So I am still need correct information from you guys....., because I want to implemented it to my MicroBoard.
Thanks.
SB.
Dear All,
LCD 128X64 C BLUE
Spesification :
- Type of LCD : STN
- Backlight : white
Thanks.
SB.
One of other I got the information from here https://www.google.co.id/imgres?imgurl=http%3A%2F%2F2.eewimg.cn%2Fnews%2Fuploadfile%2Fdygl%2F%2F201112%2F20111223105302742.jpg&imgrefurl=http%3A%2F%2Fwww.eeworld.com.cn%2Fdygl%2F2011%2F1223%2Farticle_9550.html&docid=RzoE9QkPlSje6M&tbnid=x10F04jyhszNsM%3A&w=700&h=366&bih=700&biw=1360&ved=0ahUKEwimxpiVvvDPAhWDppQKHb5KBeAQMwgdKAEwAQ&iact=mrc&uact=8#h=366&w=700, but not sure.
I see on my GLCD for PIN 17 (Anode), 18 (Katode) & PIN 3 (Ground).
Also, I found another GLCD for total PIN 18, PIN 1 (VDD), PIN 2 (VSS) and PIN 17 (Anode), PIN 18 (Katode).
The datasheets you show are for 1264, not 12864.
Klaus
Probably you searched the whole internet for more or less unreliable informations.
Why don't you look for the manufacturer's homepage..
* select the 128 x 64 dot graphic displays
* select the only one blue JHC12864C display
* download the document.
That's the most reliable source of information I know...
And it takes only one minute of time
Klaus
You follow the pin arrangment of Ampire GLCD in Proteus. it matches with it.
When searching I am not found that Datasheet, and I try with another keyword "JHDLCD" then I founded it company website.
Here is a link for :
GLCD 128x64 18 Pin Blue Colour = Board Info JHD12864C-C3 (D091201), **broken link removed**
GLCD 128x64 20 Pin Green Colour = Board Info JHD12864E (622M9) (D120618),
Anyway..., Thanks Klaus.
Thanks,
SB
Klaus,
When I searching, I am not found it, after few times with keyword "JHDLCD" then I founded that manufacture website of JHD LCD.
Okada,
I am worry to following that information from Proteus since I am not have the correct Board series Number.
Anyway I have solved this.
Here are the link :
1). GLCD 128x64 Blue Colour 18 PIN, Board Serie Number JHD12864C-C3 (D091201)
2). GLCD 128x64 Green Colour 20 Pin, Board Serie Number JHD12864E (622M9) (D120618)
Thanks,
SB.
