Need diagram of a voltmeter using PIC
John_OR
Junior Member level 3
Has anyone of you designed a voltmeter using PIC? If yes, can you post a circuit diagram for me to the board. Thanks in advance.
usb voltmeter
There's lots of way you can do it aslo you can do a search on goolge
What's the point in having the curcuit wiht the hex file
here are some
https://wiredworld.tripod.com/tronics/hiresdvm.html
http://electronics-diy.com/product_details.php?pid=271&name=Dual%20Channel%2070V%20PIC%20Voltmeter%20(Parts)
But I prefer to design my own, I used a max7219 chip a 18F4550 dual meter's amp/voltage and upload data via usb port
    John_OR
voltmeter with pic
I am new here and I was not expecting such quick and informative reply to be honest. Thanks wizpic.
Let me tell you what I am looking for in details: I am using a PIC with A/D converter and the problem is; I want to measure the mains Voltage which is 220 V AC with PIC. Therefore I need to downscale the input voltage first (with a transformer for instance) to give it as an input voltage to the PIC. I couldn't make the downscaling part of the circuitry. The transformer does not accomplish the downscaling precisely, I thnk I need extra circuitries.
voltmeter pic
any simplest one useing pic16f72 , lcd ,asm ?
or only asm is suficient .
voltmeter using pic
thanks manish, but what i want is a precise voltage downconverter which can provide the analog input for the PIC
pic microcontroller voltmeter
this is harmful but , you can use /50 factor for 20mv step for direct mesurment .
Reactions: skajay
    skajay
