Nedd help for IC 6.1 icfb setting (IC 6.* setting)
kapilsn
Member level 4
Member level 4
IC 6.* setting
In latest ICFB ,if we have vias stacked on top of each other ,they get attached and we are not able to move or select a particular vis in the stack.
Any idea of any switch present which can disable this?
Kapil
IC 6.* setting
if you don't like via stacks then don't use them... add individual via arrays and arrange them as you like... or you can use via cuts on specific layers
Re: IC 6.1 icfb setting
Hi oermens,
Even if we place vias one by one on top of each other,they get attached ones we keep they on top of each other.and at a later stage iof we want to delete one of the vias,it doesnt allow me to select that particular vis.Instead the all the vias which are placed are selected.
Kapil
if you want to remove individual vias from an array use via cuts or flatten the array and delete the ones you like
