uselessmail
Junior Member level 3
Hi there!
I wrote two programs in VHDL, one to generate a PRBS sequence and another to generate a square signal of 100 Mhz. For both these signals I took the output at the SMA port on the FPGA board (Xilinx SP601). Now I want to multiply these two signals and get the output again at the SMA port.
For the PRBS sequence, I got the output in the register
. To get the data serially out from the SMA port I created another register 'mlbs_out' which is an 'std_logic'. I copied the data into mlbs_out in the following manner:
For the square signal, I simply got the output in a register 'bout' which is an 'std_logic'
Now when I use the simple multiplication operator I get an error. The code I use is:
The error I get is, "found '0' definitions of operator "*", cannot determine exact overloaded matching definition for "*" "
I am using "STD_LOGIC_UNSIGNED.ALL" library. I also tried using the "ARITHMETIC.ALL" library and then writing the sign of the signals everywhere but to no avail.
Could someone please explain how I can get over this problem?
data_out std_logic_vector (9 downto 0)
mlbs_out <= data_out(9);
data_out(9 downto 1) <= data_out(8 downto 0);
LED_OUT <= ((mlbs_out)*(bout));
