Multiple I2C LCD CCS C project
milan.rajik
Banned
This is Multiple I2C LCD code. It is written using CCS C Compiler version 5.044. This si tested in Proteus and also EasyPIC v7 development board with 2 x 20x4 LCDs. LCDs should be HD44780 or compatible. I have used I2C LCDs and I2C LCD modules from Banggood.
I will soon post mikroC PRO PIC and AVR versions of the code here.
With this you can have 8 LCDs. Any combination of 16x2, 20x2 and 20x4.
If you have I2C device like DS1307 then you can have 7 LCDs.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
#define _LCD_FIRST_ROW          0x80     //Move cursor to the 1st row
#define _LCD_SECOND_ROW         0xC0     //Move cursor to the 2nd row
#define _LCD_THIRD_ROW          0x94     //Move cursor to the 3rd row
#define _LCD_FOURTH_ROW         0xD4     //Move cursor to the 4th row
#define _LCD_CLEAR              0x01     //Clear display
#define _LCD_RETURN_HOME        0x02     //Return cursor to home position, returns a
                                         //shifted display to its original position.
                                         //Display data RAM is unaffected.
#define _LCD_CURSOR_OFF         0x0C     //Turn off cursor
#define _LCD_UNDERLINE_ON       0x0E     //Underline cursor on
#define _LCD_BLINK_CURSOR_ON    0x0F     //Blink cursor on
#define _LCD_MOVE_CURSOR_LEFT   0x10     //Move cursor left without changing
                                         //display data RAM
#define _LCD_MOVE_CURSOR_RIGHT  0x14     //Move cursor right without changing
                                         //display data RAM
#define _LCD_TURN_ON            0x0C     //Turn Lcd display on
#define _LCD_TURN_OFF           0x08     //Turn Lcd display off
#define _LCD_SHIFT_LEFT         0x18     //Shift display left without changing
                                         //display data RAM
#define _LCD_SHIFT_RIGHT        0x1E     //Shift display right without changing
#define LCD_RS PIN_B4
#define LCD_EN PIN_B5
#define LCD_D4 PIN_B0
#define LCD_D5 PIN_B1
#define LCD_D6 PIN_B2
#define LCD_D7 PIN_B3
#define EN_DELAY 100
#define LCD_STROBE {output_high(LCD_EN); delay_us(EN_DELAY); output_low(LCD_EN); delay_us(EN_DELAY);};
#define  Waddr1 0x4E
#define  Waddr2 0x4C
void I2C_LCD_Cmd(char address, char out_char);
void I2C_LCD_Chr(char address, char row, char column, char out_char);
void I2C_LCD_Chr_Cp(char address, char out_char);
void I2C_LCD_Init(char address);
void I2C_LCD_Out(char address, char row, char col, char *text);
void I2C_LCD_Out_Cp(char address, char *text);
void CustomChar(char address, char pos_row, char pos_char);
char msg1[] = "I2C LCD 4 Bit";
char msg2[] = "PIC18F46K22 8 MHz";
char msg3[] = "CCS C, EasyPIC v7";
char msg4[] = "LCD address 0x07";
char msg5[] = "LCD address 0x06";
char const msg6[] = "Const Text Test";
char const character[] = {10,21,17,10,4,0,0,0};
/*   LCD_I2C found with PCF8574
         P7,P6,P5,P4 of PCF8574 = MSbits DB7,DB6,DB5,DB4 of LCD Display.
         P3 is hardware display bit (BackLight : 1 = on / 0 = off)
         P2 is hardware E display bit clock : E = 1 -> E = 0 active
         P1 is R/W hardware Read/Write bit hardware : Read = 1 / Write = 0
         P0 is RS hardware Register Select : CmdReg = 0 / DataReg = 1
void I2C_LCD_Cmd(char address, char out_char) {
    char hi_n, lo_n;
    char rs = 0x00;
    hi_n = out_char & 0xF0;
    lo_n = (out_char << 4) & 0xF0;
    I2C_Start();
    I2C_Write(address);
    I2C_Write(hi_n | rs | 0x04 | 0x08);
    delay_us(50);
    I2C_Write(hi_n | rs | 0x00 | 0x08);
    delay_us(100);
    I2C_Write(lo_n | rs | 0x04 | 0x08);
    delay_us(50);
    I2C_Write(lo_n | rs | 0x00 | 0x08);
    I2C_stop();
    if(out_char == 0x01)Delay_ms(2);
void I2C_LCD_Chr(char address, char row, char column, char out_char) {
    char hi_n, lo_n;
    char rs = 0x01;
    switch(row){
        case 1:
        I2C_LCD_Cmd(address, 0x80 + (column - 1));
        break;
        case 2:
        I2C_LCD_Cmd(address, 0xC0 + (column - 1));
        break;
        case 3:
        #ifdef LCD16X4
         I2C_LCD_Cmd(address, 0x90 + (column - 1));
        #else
         I2C_LCD_Cmd(address, 0x94 + (column - 1));
        #endif
        break;
        case 4:
        #ifdef LCD16X4
         I2C_LCD_Cmd(address, 0xD0 + (column - 1));
        #else
         I2C_LCD_Cmd(address, 0xD4 + (column - 1));
        break;
    I2C_Start();
    I2C_Write(address);
    delay_us(50);
    delay_us(100);
    delay_us(50);
    I2C_stop();
void I2C_LCD_Chr_Cp(char address, char out_char) {
    char hi_n, lo_n;
    char rs = 0x01;
    I2C_Start();
    I2C_Write(address);
    delay_us(50);
    delay_us(100);
    delay_us(50);
    I2C_stop();
void I2C_LCD_Init(char address) {
     char rs = 0x00;
     I2C_Start();
     I2C_Write(address);
     delay_ms(30);
     I2C_Write(0x30 | rs | 0x04 | 0x08);
     delay_us(50);
     I2C_Write(0x30 | rs | 0x00 | 0x08);
     delay_ms(10);
     delay_us(50);
     delay_ms(10);
     delay_us(50);
     delay_ms(10);
     I2C_Write(0x20 | rs | 0x04 | 0x08);
     delay_us(50);
     I2C_Write(0x20 | rs | 0x00 | 0x08);
     I2C_Stop();
     delay_ms(10);
     I2C_LCD_Cmd(address, 0x28);
     I2C_LCD_Cmd(address, 0x06);
void I2C_LCD_Out(char address, char row, char col, char *text) {
    while(*text)
         I2C_LCD_Chr(address, row, col++, *text++);
void I2C_LCD_Out_Cp(char address, char *text) {
    while(*text)
         I2C_LCD_Chr_Cp(address, *text++);
void CustomChar(char address,char pos_row, char pos_char) {
  char i;
    I2C_Lcd_Cmd(address, 64);
    for (i = 0; i<=7; i++) I2C_Lcd_Chr_Cp(address, character[i]);
    I2C_Lcd_Cmd(address, _LCD_RETURN_HOME);
    delay_ms(2);
    I2C_Lcd_Chr(address, pos_row, pos_char, 0);
void main() {
   I2C_Speed(100000);
   I2C_LCD_Init(Waddr1);
   I2C_LCD_Cmd(Waddr1,_LCD_CURSOR_OFF);
   I2C_LCD_Cmd(Waddr1,_LCD_CLEAR);
   I2C_LCD_Init(Waddr2);
   I2C_LCD_Cmd(Waddr2,_LCD_CURSOR_OFF);
   I2C_LCD_Cmd(Waddr2,_LCD_CLEAR);
   I2C_LCD_Out(Waddr1,1,1,msg1);
   I2C_LCD_Out(Waddr1,2,1,msg2);
   I2C_LCD_Out(Waddr1,3,1,msg3);
   I2C_LCD_Out(Waddr1,4,1,msg4);
   I2C_LCD_Out(Waddr2,1,1,msg1);
   I2C_LCD_Out(Waddr2,2,1,msg2);
   I2C_LCD_Out(Waddr2,3,1,msg3);
   I2C_LCD_Out(Waddr2,4,1,msg5);
   delay_ms(5000);
   I2C_LCD_Cmd(Waddr1, _LCD_CLEAR);
   I2C_LCD_Out(Waddr1,1,1,(char*)msg6);
   I2C_LCD_Out(Waddr1,2,1,(char*)"Direct Text Passing");
   CustomChar(Waddr1,3,10);
   I2C_LCD_Cmd(Waddr2, _LCD_CLEAR);
   I2C_LCD_Out(Waddr2,1,1,(char*)msg6);
   I2C_LCD_Out(Waddr2,2,1,(char*)"Direct Text Passing");
   CustomChar(Waddr2,3,10);
   while(TRUE){
      //TODO: User Code
Sorry, DS1307 address is fixed and it is 0xD0. So, You can have DS1307 or any other I2C device with fixed I2C address and also 8 LCDs to display different datas.
  • I2C LCD rev2.rar
Updated version. No you can use any combination of 16x2, 16x4, 20x2 and 20x4 LCDs. You can have 8 LCDs to display different things.
If code is modified to use i2c1 and i2c2 then 16 LCDs can be used with PIC having 2 I2C bus. I need such a system to make a calendar system.
  • I2C LCD rev3.rar
