Derun93
Member level 3
with MSP430G2553, I will control 4 switches by using timers. TimerA 1.0 counts and TA1.1 can determine the period for switch1. TA0.0 counts TA0.1 can determine the period for switch2. What can ı do for switch3 and switch4. All duty cyles and frequencies are the same for each switch But no switch are opened at the same time. for example, the of the switches are 1MHz and duty cycle %80. this switch is opened and closed 50 times then stopped. I check my control algorithm then another switch or the same switch can cycle again but do not forget no 2 switch work at the same time.
Is there something I can do for increasing count of timers ?
Thank you.
Thank you.
