Msc thesis related issue
cehan
Junior Member level 2
hi every one
i had finished all my calculation in my Msc thesis it was in microstrip antenna design,
my question related to a problem faced me now at the end of my work
where the last chapter related to antenna fabrication and its measurement
but the problem that in hfss simulation i get the desired band 2.5 and 5 ghz
but in fabrication the antenna is far from that where i get 3.4 and 5.4 ghz
am i able to publish my thesis with these differences,,,, where my supervisor said that you can publish your thesis with this condition
is this normal or will effect my thesis.
thanx alot
I am not sure what the question is but for the most part either your filtering or tolerances aren't ideal and they were exploited in the real world or your simulation parameters need to be rerun. You should be able to publish it the way it is though. The conclusion and findings should include the differences and what the suspect is and any follow up data that it would take to correct this.
