I wonder whether this is really asking for the frequency at
which the kooky input network starts to allow output toggle
instead of sitting there doing nothing.
Not that I know all about what causes latch-up, but I understand it can occur when the input terminals are exposed to a voltage outside the supply rails. In your schematic this might happen, if the input receives a sufficiently high frequency, at sufficient amplitude. (Slower frequencies are blocked by the high-pass filter, formed by the RC network.)
A low-pass filter is at the op amp's lower input. This complicates things, of course.
I don't think anything about latchup sensitivity can be
deduced from the info provided. Physical design features
are largely what matter, one part can be made to latch up
with a few mA of pin-substrate current and another, never
at a hundred mA.
I think it's a mis-expression of the real question, whatever
that might be.
