[MOVED] differintial signal to open collector output
raman00084
Full Member level 6
in my panasonic drive the encoder output is a differential signal
A+
A-
B+
B-
Z+
Z-
HOW TO CONVERT DIFFERENTIAL SIGNAL TO OPEN COLLECTOR OUTPUT
Re: differintial signal to open collector output
Use open collector Op-Amp or Comparator like LM311.
Regards
Give the signals to a OPAMp in differential mode and if needed take differential ended output. Use opamps with differential ended output with open collector or open drain.
