MOSFET Behaviour
TXRX
Full Member level 2
I Attached schema with 3 MOSFETs that prevent from capacitors C34, C35 to charge at 3 different time interval.
Do you think that MOSFETs can be damaged from from differnet timing of satuartion for each MOSFET ?
I put a Diodes that protect from situation that the capacitors charge for voltage and the MOSFET will discharge the capacitors and will develop a peak of current at MOSFET.
Thanks,
Doron
How do the three MOSFETS produce three different timing intervals?
Rds will be so small compared to the 1K series resistance that that any combination of them turning on will have the same effect. If you are driving PWM you only need one MOSFET.
Transistor power dissipation in maximal power point is 182 mW, below Pmax spec. No risk of overload.
