ModelSim simulation Query
vickyuet
Member level 2
pakistan
On running a simulation if I had a check of stopping a simulation(say #200 $stop), test-bench code window popup with pointer to line #200 $stop .The problem is if at that moment I need to edit contents of test-bench code I will not able to do that even restart option not worked.Why ???But if I manually stop the simulation (choosing sim tab,right clicking --End simulation) reopen test-bench from project than I can edit it.Is there any direct method or I had to repeat all the steps to edit the file???
Regards,
